2
Notification vibration pattern one plus 7 pro missing?
  1. mattalter
    Cupcake May 15, 2019
    mattalter , May 15, 2019 :
    So, I can't find how to change the vibration pattern for notifications. Is this coming in a later update. Also while I expect the vibration overall to be better then 6t, is better but still missing notification since the vibration is still weak even on strong.
    It would be good to allow changing the vibration pattern for notification and allow another level of vibration beyond strong.
    txs
    Matt
