Notification Volume
  1. slufoot69
    Eclair Aug 23, 2019
    slufoot69 , Aug 23, 2019 :
    On all my previous Android phones I always had a notification volume but on the OP7 Pro you only have ringtone, media and alarm.
    How do you adjust notification volume?
    TnmMartins likes this.
  2. Aakash047
    Gingerbread Aug 23, 2019
    Aakash047 , Aug 23, 2019 :
    The notification volume is the same as your ring volume itself that is, lower ring vol means lower notification vol and vice versa. It's no longer given as a seperate option.
  3. slufoot69
    Eclair Aug 23, 2019
    LyleBlake likes this.
  4. xnutzii
    Lollipop Aug 23, 2019
    xnutzii , Aug 23, 2019 :
    You probably had a Samsung before, right? Because that's actually how Android handles volumes.
    Samsung is the only manufacturer that does this (I think, LG, too? correct me pls.)
  5. slufoot69
    Eclair Aug 23, 2019
    Your are correct, I have had Samsung and LG in past. First OP7pro. Absolutely [e]1f44d[/e] love it.
    xnutzii likes this.
  6. xnutzii
    Well, great to hear, but you know what's not great?
    I always read people enjoying the 7 Pro, and I'm using a 6T, which makes the decision to buy a 7T much much more likely, and I don't want to spend money every year to "upgrade" lol
    Either way, I don't think you can manage notification volume externally at all, not even with root, as I'm rooted and haven't seen this yet, maybe with Xposed though.
  7. slufoot69
    Eclair Aug 23, 2019
    I will say that this will be my phone for many many moons... lol I cannot afford to upgrade year after year.
  8. micp69
    Cupcake Aug 23, 2019
    micp69 , Aug 23, 2019 :
    If you are rooted with Magisk, install the RICE ROM and it will enable you to set notification and ringtone volumes separately as they should be
  9. G_android_x14
    G_android_x14 , Aug 23, 2019 :
    Stock android doesn't have this, I wish it would get it. I have been Motorola and Nexus, now Oneplus - the only thing samsung has that i miss - i had a couple of samsungs, not bad, but the colors and icons hurt my eyes.
