28
Other Notifications issues on Nougat?
  1. SV3NNER
    Cupcake May 24, 2017
    SV3NNER , May 24, 2017 :
    when will this be fixed. i not recieve many notifications from FB Messenger if the phone is not used for like an hour.
    Turn off doze doesnt help. i try many things suggested but nothing helps.
    #81
  2. tarekzein
    Cupcake Jun 24, 2017
    tarekzein , Jun 24, 2017 :
    I too have the same problem! it affects notifications, installing apps from play store (download reaches 100% then nothing and the download/update progress notification disappears too)
    no pattern! can't know what helps to solve it.....my smartwatch is being disconnected too when this happens
    #82
    Better7 likes this.
  3. lennert1984
    Cupcake Jun 28, 2017
    #83
  4. Better7
    Donut Jul 4, 2017
    Better7 , Jul 4, 2017 :
    Same here.
    I add that widget from some apps stop working fine.
    #84
  5. guenole_k
    Froyo Aug 15, 2017
    guenole_k , Aug 15, 2017 :
    Hey everyone,
    I'm on my OnePlus 5 and I'm so confused. I don't know if it's a nougat problem or OnePlus one. However, as y'all, I don't receive notifications, only if I'm going to the home screen or open the app. What's confusing is that I don't use agressive doze and WhatsApp is also in the not optimised app list...
    What's disturbing me is that some app just... Close when I open it and I have to reopen to get the normal behavior. I don't know if it's a agressive RAM management or a pour doze management from OnePlus or Google... But it's now horrible to use !
    Even got the Android wear disconnect thing !! I've stopped using my smartwatch because it always ask to pair.
    OnePlus 5 Slate Gray : 6Go RAM/64 Go ROM
    #85
  6. joseah
    Cupcake Nov 9, 2017
    joseah , Nov 9, 2017 :
    Same problem here.
    Some notifications disappear from status bar after few seconds.
    For instance, Telegram, Google keep, Calendar, facebook...
    #86
