Notifications not arriving on OP7 Pro
  1. Happygiri123 Cupcake May 30, 2019
    Happygiri123, May 30, 2019 :
    I have been using OP7 Pro from last few days and I have been facing this issue where notifications from WhatsApp arrives late. I have tried everything but nothing worked till now.
  2. PHB1969 Cupcake May 31, 2019
    PHB1969, May 31, 2019 :
    I have had this too. App goes to sleep, sending phone only shows a single tick in what’s app, second tick appears and goes blue when receiving phone “wakes up”.
    When I set up my OP7 pro, I did a google transfer, but then the OP switch app. I think that screwed it. I did a reset and installed all apps from scratch and then used OP switch to migrate the data across, not apps or OP launcher.
    So far, this has worked.....for me. Hope you can get yours working too.
  3. MauroB88 Cupcake Jun 5, 2019
    MauroB88, Jun 5, 2019 :
    I have the same problem. I have tried everything. I have send the phone For assistance but it came back with still the defect. I don't know what to do yet.
  4. I1558436067746 Eclair Jun 5, 2019
    I1558436067746, Jun 5, 2019 :
    same story. contact support and submit your report . Hopefully it will make them to fix it faster with update
  5. MauroB88 Cupcake Jun 6, 2019
  6. The_Spark Eclair Jun 6, 2019
    The_Spark, Jun 6, 2019 :
    I went into battery optimization and unchecked the apps I want notifications from. It´s in the battery settings.
    Messenger was set to optimized on mine and I kept missing notifications.
  7. Happygiri123 Cupcake Jun 6, 2019
    Happygiri123, Jun 6, 2019 :
    That should ideally work but it isn't working for me and many other users
  8. The_Spark Eclair Jun 6, 2019
    Have you tried turning adaptive battery off in the battery settings? Furthermore when you swipe down your notifications there is a "manage notifications" text which you can click ... there you can check if your apps are set correct.
    Could as a last resort (me brainstorming) also be dependency issue, if a certain other app sleeps then Whatsapp may not relay a message until that app wakes up. F.ex. the gallery .... but this is just a guess, shot in the dark.
  9. MauroB88 Cupcake Jun 6, 2019
    MauroB88, Jun 6, 2019 :
    Maybe i have fixed the problem downloading push notifications fixer (app) from PlayStore.
  10. The_Spark Eclair Jun 6, 2019
    Did you get your issue fixed? In the same menu where you do app battery optimization there are three dots on top, clicking those gives you two options and one of these disables wifi while the phone sleeps.
  11. Happygiri123 Cupcake Jun 7, 2019
    Happygiri123, Jun 7, 2019 :
    As I have mentioned I have tried all these things before starting the thread and still it didn't work for me.
