Notifications sound bug
  1. DaveThe3rd
    Cupcake May 24, 2019
    DaveThe3rd , May 24, 2019 :
    Hi guys, I'm having a little problem with my OP7 Pro.
    Basically in vibration mode my notifications use media volume and it shouldn't be like that. I've checked every possible setting affecting this but I can't figure it out...
    Anyone else facing this issue?
    Thanks.
  2. xnutzii
    Lollipop May 24, 2019
    xnutzii , May 24, 2019 :
    Are you getting the sound on the loudspeaker or on headphones/Bluetooth headphones?
  3. DaveThe3rd
    Both. Speakers when not connected to BT.
    BT when using headphones/connected to my car.
  4. xnutzii
    Hmm, alright, the headphone sound can be disabled if the option is enabled of course. Go to settings > sound > earphone mode > notification ringtones in earphones > Never.
    That speaker thingy is a bit weird and complicated at the same time. You may want to set the slider to ring mode, shut down the phone, and set the slider to silent and boot the phone up again, if this doesn't fix it, I'm clueless on how to fix that.
    DaveThe3rd likes this.
  5. DaveThe3rd
    This worked!
    Thank you so much! I tried to reboot it but I didn't move the slider.
    Alrighty then, good as new.
    xnutzii likes this.
  6. xnutzii
    Yaay!! Perfect!
  7. DaveThe3rd
    Cupcake May 29, 2019
    DaveThe3rd , May 29, 2019 :
    Hi there, me again.
    It seems that every morning this bug pops back up. I don't know if it's because of the charge (I leave the phone plugged overnight) or because of the new...
    Using the reboot trick mentioned above works as a temporary fix but I'd like to find a definitive one!
    Unfortunately I'm out of ideas if not a complete reset of the phone and I'd like to avoid that.
