irfanintekhab , via OnePlus 8T , May 6, 2022 : Hi guys, i am on 8t with Android 12. The notifications sound while on call is very loud in the ear and deafening. Does anyone know where can we control its volume or switch it off? Thanks
AakashAk47 , via OnePlus 8T , May 7, 2022 : Yes i thought i am the only one who is listening to this.. phut phut is very irritating as well.
irfanintekhab , via OnePlus 8T , May 8, 2022 : But no one's replying so maybe there isn't any option to change that
AakashAk47 , via OnePlus 8T , May 8, 2022 : This is the first company who was doing great earlier. Now its becoming worst day by day
LG18700 , via OnePlus 8T , May 8, 2022 : Assuming being on a call is in Full screen... Use these settings.. It should work... Settings > notifications & Status bar > Manage notifications > More > (tap) Reduce notification feedback on full screen Come back here and report findings whether it worked or not..
irfanintekhab , via OnePlus 8T , May 8, 2022 : Thanks for the answer. It is already on. And yet it's deafening
Gor. , May 9, 2022 : Hey there, I don't quite face the issue so it may be some kind of a bug or so. You can maybe trying performing a factory reset and see if it helps. Otherwise, I guess you can use the following link to submit your feedback on this to the OnePlus developers. I don't see anything much that a user can be done on this. https://forums.oneplus.com/feedback/
irfanintekhab , via OnePlus 8T , May 9, 2022 : The reduce notifications feedback option only pertains to the full-screen. As in when watching a video or such. It does nothing to the sound when on call. The deafening clicking sound when on call is not even the sound of my notification. It's just a default click sound which is very loud. This options should be in the phone settings. But I am not able to find it
xp9 , May 27, 2022 : Any success on this issue? That's really annoying voice and make's me wanna throw my phone away every time.
irfanintekhab , via OnePlus 8T , May 28, 2022 : Nope. It's still there and i don't know how to change or switch it off
xp9 , May 28, 2022 : If somehow someone somewhere could find that sound file from the filesystem and then we just remove that? Or maybe Oneplus should just fix that bug until someone looses their hearing totally - like me!
V1539080488904 , Jun 8, 2022 : Still an issue, sound is deafening when on a call! Any word on a fix/workaround yet?
