[Submitted] OB1 android 11, oneplus 8, no battery symbol
  1. firoz3321
    Froyo Sep 19, 2020
    firoz3321 , Sep 19, 2020 :
    Oneplus 8
    Open Beta 1
    No battery icon in status bar.
    If i drag the notification bar i can see the battery icon. Otherwise there is a blank space beside network signal strength icons.
  2. Suhas Klkrn555
    OnePlus Bug Hunter Staff Member Sep 19, 2020
    Suhas Klkrn555 , Sep 19, 2020 :
    We may have to check this further. Kindly check you're inbox we've dropped you a direct message. It'll be of great help if you could share the required information.
    Thanks & Regards,
    Suhas.
  3. Saisrinivasss
    Froyo Sep 24, 2020
