72
ROM [OFFICIAL][5.1.1] BlissPop by Team Bliss-Bacon [weekly][OTA]
  1. nrath
    Froyo Jan 27, 2015
    nrath , Jan 27, 2015 :
    With latest build AudioFX only working with speakers and headset. No function with Bluetooth. Is this a known bug or just MY bug? Is there a way to fix it ? Using Bose Soundlink mini
  2. Pratyush
    Gingerbread Jan 27, 2015
    Pratyush , Jan 27, 2015 :
    call waiting drops the audio of existing call... any body facing this ??
    any fix for this?
  3. gautamal
    Honeycomb Jan 27, 2015
  4. hazzavg
    KitKat Jan 27, 2015
    hazzavg , Jan 27, 2015 :
    I'll have the actual density at 410
    But the reported density at 480
    All the confusions for the phone
    And it turns out that doesn't work
  5. nrath
    Froyo Jan 27, 2015
    try to reduce the reportet density to 440
  6. hazzavg
    KitKat Jan 27, 2015
    If it doesn't work at 480
    Isn't there less chance it would change at 440
  7. anishraj
    Eclair Jan 27, 2015
    anishraj , Jan 27, 2015 :
    whenever i download and install an apk it says that im out of space but i have 45 gb space remaining
    any solutions for this?? and im using blisspop thanks :)
  8. jan110968
    Jelly Bean Jan 27, 2015
    jan110968 , Jan 27, 2015 :
    U ned to flash cm update from 20/1-15 first then the firmware
  9. hazzavg
    KitKat Jan 27, 2015
    Is it trying to install it somewhere that is lacking space on the phone
    Maybe you partitioned it somehow
  10. Giansilvio
    Giansilvio , Jan 27, 2015 :
    can you please tell me which FONT are you using in the screenshot, and possibly where to find ?
    Thanks!
    JibZ likes this.
  11. sumchamp
    Froyo Jan 27, 2015
    sumchamp , Jan 27, 2015 :
    @anishraj Download cache cleaner from playstore and clear your cache. Done.
  12. BadWolfTronic
    BadWolfTronic , Jan 27, 2015 :
    Hi all, does anyone know if there are issues with stock PA gapps? I have blisspop 1.9 with stock PA Gapps and boeffla kernel...
  13. JibZ
    JibZ , Jan 27, 2015 :
    The 1.9 changelog:
    New Build Uploaded
    BlissPop-v1.9-bacon-OFFICIAL-20150126
    http://downloads.blissroms.com/BlissPop/Official/bacon/
    PLEASE READ there have been an update from CM for Trusted Zone that is a possible fixed for new user's not needing to flash the bacon_firmware_updater. But this has not been tested. If someone that is new and has never flashed CM 12 Nightly or the updater would like to test please do and leave feedback. It will only give you a bootloop it the fix didn't work.
    I still recommend that being on the latest firmware but I still need it tested. Please test at own risk.
    Instructions institutions for new user's if not wanting to test CM patch
    Flash:
    ROM
    Gapps I use PA pico (NEW)
    https://www.androidfilehost.com/?fid=95916177934516812
    Changelog
    -Setting Add AudioFX tile
    -Add LTE tile
    -Add Look screen shortcuts centralize all option in our custom settings
    -QS add Screen timeout tile
    -Add WiFi option to show QS detail view
    -PowerWidget enable LTE button
    -Notification bfix dark text on background
    All CM updates and More..
    Still not working was changed but missing commit. Setting CM Gestures. V Camera ect. (Working on it there was a missed commit)
    Enjoy all....
    Regards,
    Vortex
    @JorgeDiesel I would like to know what font you are using in your screenshot too please ;) thanks
  14. boennekes
    Froyo Jan 27, 2015
  15. nofx161
    nofx161 , Jan 27, 2015 :
    New Build Uploaded
    Flash:
    ROM
    Changelog
    -Add LTE tile
  16. hazzavg
    KitKat Jan 27, 2015
    Tell him
    Not me
  17. Stone_88
    Gingerbread Jan 28, 2015
    Stone_88 , Jan 28, 2015 :
    Hey there, I'm not sure if you already got your answer. If you solved your problem, then ignore this. :D
    I think you need to set the "Lock screen mode" to Leave unchanged.
    I use similar profiles, one for home, work, car, default, silent and a night profile.
    In my case only the home and car profile use unsecure unlock and all the others have a pattern-unlock.
    You just have to set the type of unlock in your security settings (pin code in your case), then set "leave unchaged" for lock screen mode in every profile that should use this option and for the other profiles set "Don't ask for PIN or Password".
    This should do the trick.
    Cheers
  18. Giansilvio
    gautamal likes this.
  19. nrath
    Froyo Jan 28, 2015
    nrath , Jan 28, 2015 :
    OK, it's working with Poweramp. Had to activate the "MusicFX" function in poweramp. Now everything is working finde for me. The only thing I noticed is I have to lift up the min. CPU freq. while screen off to prevent lags and cracks. Set it to 652 MHz and now music via bluetooth speaker works like a dream. Sound is pretty good.
  20. sumchamp
    Froyo Jan 28, 2015
