52
ROM Official CM13 nightly builds rolling out for OPO
  1. LoneStar144
    Honeycomb Nov 24, 2015
    LoneStar144 , Nov 24, 2015 :
    Just a tad bit of info on official cm13 nightlys: http://www.cyanogenmod.org/blog/a-marshmallowy-cm and there is an experimental build up for download, but it will have the same issues we are having right now. https://download.cyanogenmod.org/?device=bacon
    CyanogenMod builds a new "nightly" version generally every 24 hours for each of the devices it supports. This includes the most up-to-date changes to its version of the Android (AOSP) source code.
    Source: wiki.cyanogenmod.org
    Changelog: http://cmxlog.com/13/bacon
    Bug Reports (and votes): https://jira.CyanogenMod.org/browse/NIGHTLIES
    Note: If you are flashing from previous CM versions, you MUST flash 6-compatible gapps immediately after flashing the ROM!
    Download Links:
    1. CM13 ROM: http://download.cyanogenmod.org/?device=bacon
    2. Android 6.x Gaaps: OpenGApps | BanKS GApps 6.x | more to come..
    Flashing Instructions
    Comprehensive installation instructions for CM on the OnePlus One can be found on the CyanogenMod Wiki: http://wiki.cyanogenmod.org/w/Install_CM_for_bacon
    WARNING:
    Some are having issues flashing the newest builds because of new baseband. YOU MUST use the appropriate version of twrp, as this will correctly flash the baseband.
    Tested and confirmed versions of twrp that will properly flash new basebands.
    • 2.8.6.0
    • Materialized 2.8.7.0.5
    • Materialized 2.8.7.0.6
    • 3.X
    All downloads for twrp can be found here, thanks to kumajaya: https://www.androidfilehost.com/?w=files&flid=30332
    For those wishing to use SuperSU instead of built-in root, flash the systemless SuperSU Beta.
    http://forum.xda-developers.com/showpost.php?p=64161125&postcount=3
    pikota, jstepa, mattchudry and 49 others like this.
  2. muddy46
    Jelly Bean Nov 24, 2015
  3. LoneStar144
    it's very tasty, been running unofficial builds from Sultanxda for a couple weeks now. Other than a few root issues stemming from the conversion from busybox to toybox, it's very smooth and stable. Now that official builds are starting to roll out, most of these issues should be fixed pretty quick.
    Ceasedd, Tobikage and muddy46 like this.
  4. gaster
    Moderator Moderator Nov 24, 2015
    Adugr8, Ceasedd, deviantartjr and 4 others like this.
  5. Vettesfan
    Cupcake Nov 24, 2015
  6. itacheh
    ljflevy and Vettesfan like this.
  7. LoneStar144
    gaster likes this.
  8. LoneStar144
    if you are coming from another rom, like cm12.1, cm11, oxygen, etc, you must do a clean install. even if you are on unofficial cm13 builds, i would still clean flash, just to be on the safe side.
  9. blujadajhdja
    Ice Cream Sandwich Nov 24, 2015
    blujadajhdja , Nov 24, 2015 :
    If you're on CM12.1 Nightlies, you're supposed to be able to do a dirty flash.
  10. ojaswinsingh
    Gingerbread Nov 24, 2015
    Vettesfan likes this.
  11. raiashu92
    raiashu92 , Nov 24, 2015 :
    but then also u would have to flash both rom and gapps.
    Clean flash is better ;)
  12. rkiwtir
    rkiwtir , Nov 24, 2015 :
    Oh, finally!! :D
    Edit : Even this will support cm delta right!?
    Edit 2: Pre rooted or do I need to flash su?
    *review later*
    hrangwala likes this.
  13. TheJames
  14. raiashu92
    inbuilt su there, supersu leads to bootloop
    rkiwtir likes this.
  15. rkiwtir
    Isn't that a thing is all/almost all Android M ROMs?
  16. rkiwtir
    The nexuses say hello ;)
    ladnishad, Fonetix, thesign and 2 others like this.
  17. hellboy05
  18. TheJames
    TheJames , Nov 24, 2015 :
    They're next in line. They don't have this kind of development community. OPO has an army of ROM's.
    At the thread about it. Look around buddy..
    Naveedkazi likes this.
  19. rkiwtir
    OPO developer community started to grow since this year. (It was very less during the KitKat Era of opo) but Nexus 5 has got a lot of Roms ever since it's release way back in 2012(?!?)
  20. theapu
    theapu , Nov 24, 2015 :
    Does now on tap work flawlessly in open gapps? I use slim gapps and most of times now on tap doesn't work. Only the white square appear on screen, not the now on tap cards.
    I am on sultan cm 13
