52
ROM Official CM13 nightly builds rolling out for OPO
  1. SRIDHARSWC
    Gingerbread May 29, 2016
    SRIDHARSWC , May 29, 2016 :
    Hi I am on latest nightly and found my phone taking more time to charge and getting really hot for the past one week, previously it was 2hrs. ???
  2. mariob
    mariob , May 29, 2016 :
    I am using 27th build, with no isues, no slow charge and no overheating, only system profiles not working like they should but this is old problem
    sn809 likes this.
  3. robthorley
    Ice Cream Sandwich May 30, 2016
    robthorley , May 30, 2016 :
    Trying to update from 23rd to 30th, I get "Error while starting recovery install: java.io.IOException"
    Have I left it too long to install using Cyandelta?
  4. ElRobertson
    Gingerbread Jun 2, 2016
    ElRobertson , Jun 2, 2016 :
    Anyone else facing problems with cLock Weather widget?
    I've tried Yahoo and Underground Weather Provider. With both providers and all available weather symbols.
    Problem: There are question marks shown in the forecast page... :D:p
  5. wengezhu
    Cupcake Jun 3, 2016
    wengezhu , Jun 3, 2016 :
    I am on the latest (3rd of June) just for a few minutes, and the wifi battery drain is horrible, from about 99% to start my update, and now is 86% only about ten minutes later
  6. ramcon12
    Gingerbread Jun 3, 2016
    ramcon12 , Jun 3, 2016 :
    I flashed the 3rd today, been running it for about 3 hours, with around 20 minutes of data on. Battery is 92% . I do not think the build is a problem
    rmadilobut likes this.
  7. daniga74
    Jelly Bean Jun 4, 2016
    daniga74 , Jun 4, 2016 :
    Try chronus as weather provider
    ElRobertson likes this.
  8. cssharda
    Donut Jun 5, 2016
    cssharda , Jun 5, 2016 :
    The recent apps kill button remains hidden behind the app when 6-7 apps are required to be killed. Any one know the solution pl.
  9. rkiwtir
    Ice Cream Sandwich Jun 5, 2016
    rkiwtir , Jun 5, 2016 :
    Switched back official cm13 after testing out various roms (EG: exodus, darkobas, sultan, jgcaaps etc)
    all of em had the same shitty battery back(like 1½ of sot). So it must be my battery right? I got a bit better battery life on jgcaaps like 2 hours minimum(But it doesn't have now on tap. I got an android wear now(Syncing issues with jgcaaps) . So now battery even drains when the phone is in my pocket. I switched by to this rom. Both syncing and now on tap works but the same 1½ hour sot
    Should I replace my battery? (Service center approximated that it would cost around 25-30$ including service charge. My warranty was over back in Jan. Or should I just buy the battery online and replace it myself ?)
    Or is there any last thing I can do?
  10. Ricbro
  11. sn809
    sn809 , Jun 5, 2016 :
    https://www.ifixit.com/Guide/OnePlus One Battery Replacement/30417
    I would do that, dont know where you are going to source your battery from though. Ricbro's post mentions there is a possibility that the change will help but I dont think it will be enought to inprove from 1.5 hrs SOT to anything decent.
  12. sunil201
    Donut Jun 6, 2016
    sunil201 , Jun 6, 2016 :
    Hello, What's the last reliable nighlty? I am on April 20th which had been really stable till last week, but something odd has been happening lately with system and ui crashes. Thanks
  13. HWAM
    Honeycomb Jun 6, 2016
    HWAM , Jun 6, 2016 :
    Just install the latest, all stable. I run the latest 06/06 without problems.
  14. sunil201
    Donut Jun 7, 2016
    sunil201 , Jun 7, 2016 :
    Thanks. Working good on 06/06 so far.
  15. scott2353
    Cupcake Jun 7, 2016
  16. cssharda
    Donut Jun 7, 2016
    cssharda , Jun 7, 2016 :
    On 6th & 7th nightly my battery is taking double time to re-charge. Don't know why. On 5th it was OK.
  17. MarmiteX1
    Gingerbread Jun 8, 2016
    Ricbro likes this.
  18. Deactivated User
    Jun 9, 2016
  19. Deactivated User
    Jun 9, 2016
  20. rmadilobut
    Gingerbread Jun 9, 2016
    rmadilobut , Jun 9, 2016 :
    Nope
    Deactivated User likes this.
