52
ROM Official CM13 nightly builds rolling out for OPO
  1. JayminVyas
    Ice Cream Sandwich Dec 21, 2015
    JayminVyas , Dec 21, 2015 :
    There has to be something after 4th or 5th December build, which has broken something. I am using 4th build without any reboot issue.
  2. ThePrutser
    Froyo Dec 21, 2015
    ThePrutser , Dec 21, 2015 :
    Other then the reboots, my phone also lights up spontaneously showing the time. Nothing more nothing less. It is almost like my phone keeps blinking with its entire display all the time. So I am NOT talking about the lighting up when receiving notifications.
    Ok, I have noticed that this lighting up is related to the "vibrations" it detects. I was typing on my keyboard, not like an aggressive maniac, and then my phone lights up every time. As soons as I stopped typing, the phone wouldn't lit up anymore. It seems to me like the proximity sensor is very sensitive atm....
  3. haruhisuzimiya
    Honeycomb Dec 21, 2015
    haruhisuzimiya , Dec 21, 2015 :
    UPDATE: Try out today's nightly build (20151221), or tomorrow's build (20151222), I hear that CyanogenMod have finally fixed the random reboot bug!
    About the random reboot bug on CyanogenMod 13, it appears that it was introduced in the 9th December Nightly.
    On TugaPower (which is a CM13 based ROM), the one based on the 9th December Nightly (16.1) has given me several random reboots in the course of a day, while the one based on the 8th December Nightly (16.0) has had no random reboots at all in the whole day.
    Solution: Stick to the 8th December (20151208) Nightly build until CyanogenMod devs fix this issue.
  4. robthorley
    robthorley , Dec 21, 2015 :
    Today's nightly only has two changes and I can't see that either of those will be the fix (although I am no expert) so I will look at the nightly tomorrow...
  5. Teis123
    Donut Dec 21, 2015
    Teis123 , Dec 21, 2015 :
    I thought this problem was unique to me. I reset and did a complete reinstall after a phone wipe, installed the 12/21 nightly only to find this thread with others like me! :) Well I'll watch this and see if the efficiency battery setting helps.
  6. benton
    Cupcake Dec 22, 2015
    benton , Dec 22, 2015 :
    Today nightly, installed over the previous; still GPS issues, random reboots. And for real, I'm getting tired as this is an awful problem. The phone simply reboots when you must need it, not even nearly usable at all.
  7. benton
    Well I just flashed another ROM, I would even live with the GPS bug, but random reboots... more frequent, just can not support... bye bye CM13
  8. AntMunny
    KitKat Dec 22, 2015
    theshinybeast likes this.
  9. michaelj
    Gingerbread Dec 22, 2015
    michaelj , Dec 22, 2015 :
    I only get a random reboot around once a day. Not annoying enough to cause problems but definitely hoping its solved.
    Running 20151220 and apart from the reboot its quite nice, battery lasting as good as earlier nightlies (they took a dive for a while). 20151222 my widgets are broken.
  10. mohdsubhan
    mohdsubhan , Dec 22, 2015 :
    Apart from random reboots, does anyone having dialer issues?
    My dialer is painfully slow in opening, loading call logs and making call.
    darushah.shah likes this.
  11. semper80
    Ice Cream Sandwich Dec 22, 2015
    semper80 , Dec 22, 2015 :
    Deleted
  12. semper80
    Vendor files causes ramdom reboot. dlhxr made a flashable zip to fix that. It's just a temporary fix. Download it from here.
    robthorley, rkiwtir and xythiii like this.
  13. menisasson
    Eclair Dec 22, 2015
    menisasson , Dec 22, 2015 :
    Thanks for this
    Applied the fix, so far 1 hour without reboot (before I had at least 2 an hour). Will update later with any change (or no change hopefully)
    If there is already a fix why isn't it merged into the nightlies?
  14. killerbee13
    Jelly Bean Dec 22, 2015
  15. rkiwtir
    rkiwtir , Dec 22, 2015 :
    Does it break ota from cmDownloader too?
  16. stephensfone
    Honeycomb Dec 22, 2015
    stephensfone , Dec 22, 2015 :
    It's a nightly, of course it has bugs!
    Teis123 likes this.
  17. benton
    AntMunny likes this.
  18. semper80
    Yes, I think.
  19. theshinybeast
    Marshmallow Dec 22, 2015
    theshinybeast , Dec 22, 2015 :
    Go for SlimSaber it's rock solid right now and great battery life. I'm averaging 6 hrs sot.
  20. Teis123
    Donut Dec 22, 2015
    Teis123 , Dec 22, 2015 :
    Giving this a try already had three reboots with last nights update....
