52
ROM Official CM13 nightly builds rolling out for OPO
  1. Jupeeeeee
    Jelly Bean Dec 23, 2015
    Jupeeeeee , Dec 23, 2015 :
    Great. I just got my opo fixed today, and instantly started flashing this. now it's been trying to flash the rom for the past ~20 minutes. And force reboot wouldn't be a good idea. using the 20151222.
  2. Jupeeeeee
  3. Knarre
    Gingerbread Dec 23, 2015
    Knarre , Dec 23, 2015 :
    22/11 works way better for me than the previous ones. No reboot so far
    AntMunny likes this.
  4. RicoBiwan
    Cupcake Dec 23, 2015
  5. se7enlyn
    Ice Cream Sandwich Dec 23, 2015
    se7enlyn , Dec 23, 2015 :
    21/11 is 12.1
    beyond that is 13.0
  6. avibored
    Honeycomb Dec 23, 2015
    avibored , Dec 23, 2015 :
    On 1223 .. No reboots for 3 hours straight..
    Still going strong with no reboots..
    Are they actually fixed ?
    Edit: damn had one just a few minutes ago..
  7. menisasson
    Eclair Dec 23, 2015
    menisasson , Dec 23, 2015 :
    Yeah so I take it back, reboots came back and big time. At least 6 in the last 12 hours.
    Fix doesn't work..
  8. RicoBiwan
    RicoBiwan , Dec 23, 2015 :
    Oupss .. I did read 22/11 ... Sorry !
    One reboot after e few minutes in 1223 ... And 2 or 3 in 3 hours ... :(
  9. Coastie
    Coastie , Dec 23, 2015 :
    Is anyone not having reboots on 13 builds, or are reboots a sure thing at this point?
  10. xythiii
    xythiii , Dec 23, 2015 :
    No reboot here 3 hours, but usualy starts happing when you charge phone i let ya know later..
    se7enlyn likes this.
  11. darkangelpt
    Eclair Dec 23, 2015
  12. killerbee13
    killerbee13 , Dec 23, 2015 :
    2 reboot today with 23/12 build. My opo almost always reboot when i put it on charge and get full battery
    ArtVandelay and xythiii like this.
  13. Teis123
    Donut Dec 23, 2015
    Teis123 , Dec 23, 2015 :
    If anyone else want to try this, I have profiles turned off and have not had a reboot yet this morning. I do have the "fix" applied but did have reboots shortly after applying that and prior to disabling sound profiles.
  14. hbvdh
    hbvdh , Dec 23, 2015 :
    No reboots at all, only when flashing new nightly. Stable as a rock.
  15. RicoBiwan
  16. mangatinanda
    mangatinanda , Dec 23, 2015 :
    Okay... I couldn't connect my phone to computer. USB connection working on OPO CM 13 nightly? I am currently on 23/12 build and its not working for me :(
  17. RicoBiwan
    You have to pull down the android menu and select usb connection ... You then have to check "Transfer files" ..
    mangatinanda likes this.
  18. RicoBiwan
  19. rkiwtir
    rkiwtir , Dec 23, 2015 :
    So I checked,
    The flashable zip that's supposed to fix the reboot issue doesn't work.(20th build) . Will flash 24build when released and report if it's fixed. Currently, random Reboot is still a thing.
  20. johncel.espares
    Froyo Dec 23, 2015
