52
ROM Official CM13 nightly builds rolling out for OPO
  1. 0xTJ
    Gingerbread Nov 24, 2015
    0xTJ , Nov 24, 2015 :
    http://opengapps.org/, select ARM, 6.0 (for marshmallow), and select which variant of apps is best. (Hint: clicking on the text of the variant will bring you to a page with what is included in each.)
    #61
    cacaarl and HWAM like this.
  2. bakal_daw
    Honeycomb Nov 24, 2015
    bakal_daw , Nov 24, 2015 :
    I got to take it back from my wife! I think it's not going to be easy...;)
    #62
  3. HWAM
    HWAM , Nov 24, 2015 :
    So I need the "nano" package as minimal package?? I can update the rest from the playstore?
    Why do I need to install the GApps anyway? Why is a dirty flash from cm12.1 to cm13 ending in a bootloop? Is it due to the security changes in cm13?
    #63
  4. NicholasYeo
    Donut Nov 24, 2015
    NicholasYeo , Nov 24, 2015 :
    Guys, I'm sorry I just faced the following problem, I didn't notice the update was for 13.0 And now I'm stucked at bootloop, I tried flashing back my previous version but it still have bootloop problem, Now I am only able to access safemode and I'm downloading the latest gapps but i dont know how to i put it in my device >< Sorry I'm a real careless here, know not much about these
    #64
  5. 0xTJ
    Did you dirtyflash your previous version, do a backup restore, or do a full wipe and flash?
    #65
  6. 0xTJ
    For your first question, yes. All you really NEED is play store, as all the others can be installed through it, though they will not replace stock cm apps, so you will have multiple camera, calendar, keyboard, etc. apps.
    You need GApps because the play store is required to be installed as a system app, and, though you could separately install google apps, they will not function correctly.
    As to the bootloop, that's not yet fully known here yet, but your hypothesis could be true.
    #66
    HWAM likes this.
  7. csabreu
    Ice Cream Sandwich Nov 24, 2015
    csabreu , Nov 24, 2015 :
    OP2 owners should be green with envy right now... and I'm not talking about some unofficial MM ROM, which a few have been around for a while.
    #67
  8. theshinybeast
    Marshmallow Nov 24, 2015
    theshinybeast , Nov 24, 2015 :
    Admit it, you've missed her/him:pThat Nexus 6 just ain't the same;):D
    BTW Try Sultan's Unofficial build very smooth for an Alpha. I've been running it as my daily driver for a couple of weeks now.
    #68
  9. NicholasYeo
    Donut Nov 24, 2015
    Hello, I dont know what dirty flash is, I updated all my previous versions ota from the phone itself and today the 13 came in and i did the same without realizing. No backup and i cannot restore to previous version, just flash my previous updates that haven't been deleted yet
    #69
  10. 0xTJ
    That's probably not a good idea. Stuff changes, and its might not change back nicely, though if it does work, it's pretty lucky. Dirty flashing is flashing a zip without wiping the device first.
    #70
  11. HWAM
    Thx. I had the bootloop updating from cm12 to cm12.1 (forgot to flash GApps update) so I want to be sure now!
    #71
  12. NicholasYeo
    Donut Nov 24, 2015
    Now I'm stucked with 12.1 and I only can boot into safe mode, Normal boot will keep me at the boot animation. What can I do to recover the phone and update? I've downloaded the Gapps for 6.0 and the cm13 file is in my phone, How do i continue with flashing? Do i have to wipe anything? How can I transfer Gapps file into my phone? It is crucial now to wipe all my data or i can do it by skipping internal storage wipe? Thanks Bro ><
    #72
  13. LCOSTA17
    #73
  14. 0xTJ
    UPDATE: Clean flash successful. Also, probably wont be on for the next few hours.
    #74
  15. 0xTJ
    If you want, backup data partition in recovery, then do advanced wipe, doing only cache, dalvik, data, and system, then flash the cm zip. Worked for me.
    #75
  16. rkiwtir
    rkiwtir , Nov 24, 2015 :
    If you don't mind losing your data.
    Place6.0 gapps and rom in phone.
    Reboot to recovery.
    Go to wipe,
    Advanced.
    Cache dalvik system.
    Install
    Rom
    Gapps
    Wipe cache
    Reboot
    #76
  17. Vadomata
    Jelly Bean Nov 24, 2015
    Vadomata , Nov 24, 2015 :
    They actually are going to make CM13 for OPO. Cool :) Going to use this if the camera quality is the same as In 5 :)
    #77
  18. darushah.shah
    Froyo Nov 24, 2015
    #78
    ArtVandelay likes this.
  19. matssa
    matssa , Nov 24, 2015 :
    Activate airplane mod and it should work (activate and deactivate i think)
    #79
  20. darushah.shah
    Froyo Nov 24, 2015
    darushah.shah , Nov 24, 2015 :
    Tried that, still no go. Please help me. I did clean flash of cm 13 with open gapps Mini
    #80
