52
ROM Official CM13 nightly builds rolling out for OPO
  1. AntMunny
    KitKat Dec 25, 2015
    AntMunny , Dec 25, 2015 :
    I dirty flashed it over the Dec 24th...even though it's the exact same ROM (no changes since the 24th).
    Here at work...running perfect so far
    bligus likes this.
  2. bligus
    Eclair Dec 25, 2015
    bligus , Dec 25, 2015 :
    Thank you.
    I just flashed also and having one reboot after constantly watching YouTube videos :)
  3. semper80
    Ice Cream Sandwich Dec 25, 2015
    semper80 , Dec 25, 2015 :
    I hope. I don't use it because I don't have reboots
  4. hream41
    Froyo Dec 25, 2015
    hream41 , Dec 25, 2015 :
    Installed it b4 v20151221.. I got like 4 reboots in an hour.. The i switched and tried sultanxda unofficial cm13.. Worked like a charm no reboot. Amazing battery life and touch screen sensitivity was awesome
    -just sharing
  5. hream41
    Froyo Dec 25, 2015
    Same experience. But i badly want to try mm.. So i gave it another try and flash sultans rom.. Since 12_11_2015 build. No reboot no lag.. Cant understand why the official cm keeps getting this random reboots though
  6. rkiwtir
    rkiwtir , Dec 25, 2015 :
    Someons is the xda thread said updating the recovery to Twrp (8.7.1)might help. Will have to check tho!
  7. EladKapusta
    Eclair Dec 25, 2015
    EladKapusta , Dec 25, 2015 :
    Flashed 24th build (assuming it's the same like 25th) and had a TON of reboots, like, every five minutes, so flashed the so called fix from a few pages ago, and like last time it didn't solve the problem entirely but I'm having a reasonable amount, like one every hour or two. Manageable.
  8. awatt2001
    Gingerbread Dec 25, 2015
    awatt2001 , Dec 25, 2015 :
    Flashed Back to the 9th then to the 25th. No reboots for a good few hours. Possibly a good build
  9. johncel.espares
    Froyo Dec 25, 2015
    johncel.espares , Dec 25, 2015 :
    since release the cm13(6.0.1 version) we experience the random reboot, so i use tempopary cm13(6.0) until the problem was fix.
  10. sergio.lobianco
    Eclair Dec 25, 2015
    sergio.lobianco , Dec 25, 2015 :
    I do not know if it can help someone. I was having several reboots , what I did :
    1. I downloaded the CM13 of 12.24.2015 and Opengapps Pico
    2. I did wipe - System - Data - Cache and Dalvik
    3. I installed the ROM and OpenGapps
    4. Reboot
    5. Google Play - I downloaded one by one in order of applications that use.
    6. Conclusion - Zero reboots
    The only problem is that when changing the theme gives the message that the Trebuchet stopped working, even I using New Launcher .
  11. highdiver_2000
    highdiver_2000 , Dec 25, 2015 :
    S
    Sultan is (cherry) picking only selected CM patches to be included in his build. But still not free from random reboots.
  12. Loekkiee
    Loekkiee , Dec 25, 2015 :
    To be honest, dont want to read like 10 pages of missed messages in this thread. is there already a nightly that can be downloaded that doesnt have any random reboots and f'd up screens? :)
  13. semper80
    I did some tests in CM13 Bacon. I think REBOOT appears when the radio driver conflict with memory management. Still not 100% sure.I will do some tests when I have time and come back with feedback
    ArtVandelay likes this.
  14. hream41
    Froyo Dec 25, 2015
    I started sultans rom in like 20151211. First try to this day 20151224 no reboots. No black screen. Guess its for me coz all i experience was positive. Smoother and more responsive screen. Faster response in my device better battery performance on and off screen. Thats only for me.. Tried cm13 nightly.. Awful.. Reboots everynow and then
  15. hream41
    Froyo Dec 25, 2015
    This rom worked for me
  16. Loekkiee
    Seems to work like a charm for you. Do you have a link maybe? Thanks :)
  17. lowrider
    Eclair Dec 25, 2015
    lowrider , Dec 25, 2015 :
    Since I flashed this no more random reboots even when I use different kernel ... If it's such a simple fix why doesn't the cm team implement
  18. rkiwtir
    It works for only few people. It didn't work me tho.
  19. Loekkiee
    Another question, maybe a stupid one. How do you get the daily nightly updates?
  20. MarmiteX1
    MarmiteX1 , Dec 25, 2015 :
    Hi there, daily updates are built in the ROM but the file size is quite large so there are people out who use CyanDelta app to download the ROM(small file size) and apply the update. By default the dalvik cache and cache are wiped to avoid issues.
    Instructions can be found here:
    http://www.cyandelta.com/index2213.html?q=FAQ
    Hope this helps.
    By the way Merry Xmas!
