52
ROM Official CM13 nightly builds rolling out for OPO
  1. rkiwtir
    Ice Cream Sandwich Dec 29, 2015
    rkiwtir , Dec 29, 2015 :
    Had 1reboot on 29th build. Flashed the reboot fix zip. 7 hours later, 0 reboots. And battery backup is good.
  2. raiashu92
    Gingerbread Dec 29, 2015
    AntMunny likes this.
  3. SixthStraw
    Cupcake Dec 29, 2015
    SixthStraw , Dec 29, 2015 :
    Yes, same with me, the fix work, today I had 0 reboot :D with the nightly 28 December.
  4. Trusconi
    Jelly Bean Dec 29, 2015
  5. Coastie
    Honeycomb Dec 30, 2015
    Coastie , Dec 30, 2015 :
    Bummer, word on XDA is that the new firmware in 1230 did not fix the random reboots
  6. darkangelpt
    Eclair Dec 30, 2015
    darkangelpt , Dec 30, 2015 :
    I installed 30 December update. And ruined my Sim connection. No sim card was detected. And phone was so slow. Don't use 30-12
    Had to use recovery
  7. avibored
    avibored , Dec 30, 2015 :
    system ui stopped..
    had to reboot into recovery and uninstall a theme i installed ..
    on 1230
  8. BASSNIGGA
    Cupcake Dec 30, 2015
  9. AntMunny
    KitKat Dec 30, 2015
    AntMunny , Dec 30, 2015 :
    clean flashed Dec 30th build just to get new firmware. been playing with it for 2 hours. no issues.
    I don't know what you guys are doing to make your phone inoperable...is it xposed? mods you put on your phone? MultiROM?
  10. raiashu92
    Gingerbread Dec 30, 2015
    raiashu92 , Dec 30, 2015 :
    Using 30/12 for 4 hrs now, clean flash with slim mini gapps 28/12. no reboots so far. GPS still not working indoors, didnt check outside.
    During antutu benchmark phn was pretty cool, earlier it used to get hot, they did smthng. Also the score is lower than before, maybe sm throttling.:confused:
    ArtVandelay and Trusconi like this.
  11. fred2028
    fred2028 , Dec 30, 2015 :
    I have no other mods like xposed, multi-rom, etc. Just plain CM 13 nightlies on a plain 1+ 1 on AT&T. Tried dirty flash from 12/29 to 12/30 twice, had to downgrade due to lack of cellular and then lack of WiFi upon reboot.
  12. h0aX
    h0aX , Dec 30, 2015 :
    Can someone please mirror 30-Dec-2015 nightly on GDrive?
    Facing issues with CM servers.
  13. Albarda
    Albarda , Dec 30, 2015 :
    Which TWRP version should I use to flash the latest nightly with the new firmware?
  14. fred2028
  15. Busjen
    Ice Cream Sandwich Dec 30, 2015
    Busjen , Dec 30, 2015 :
    same for me, no sim card found
  16. Trusconi
    Jelly Bean Dec 30, 2015
  17. jejecule
    jejecule , Dec 30, 2015 :
    Same here no baseband after clean flash. twrp 2.8.7.0.
    Will try with another recovery version
  18. lokesh3440
    lokesh3440 , Dec 30, 2015 :
    twrp 2.8.7.0 is infamous for flashing modems correctly. that's why you don't have RIL. Please clean flash with 2.8.6.0
    jejecule likes this.
  19. dhairyarc1
  20. rkiwtir
    rkiwtir , Dec 30, 2015 :
    Dafuq, you copying this from my post? And stop spamming -_-
