52
ROM Official CM13 nightly builds rolling out for OPO
  1. agustine
    Donut Nov 24, 2015
    #81
    ArtVandelay likes this.
  2. agustine
    Donut Nov 24, 2015
    #82
  3. Vadomata
    Jelly Bean Nov 24, 2015
    #83
  4. GU1LH3RM33
    Cupcake Nov 24, 2015
    GU1LH3RM33 , Nov 24, 2015 :
    Not flash SuperSu...
    #84
  5. Vadomata
    Vadomata , Nov 24, 2015 :
    Should I install the apk? Now I flashed the OS and gapps again and now I don't have Google Play Store anymore :D
    #85
  6. Deltastylez
    Donut Nov 24, 2015
    Deltastylez , Nov 24, 2015 :
    I dont have data either, I tried the airplone mode toggle, but no luck so far.
    any hope for the next CM nightly build tomorrow?
    or is there any other fix?
    #86
  7. hrishi21007
    Honeycomb Nov 24, 2015
    #87
    jghj and killerbee13 like this.
  8. kipperbusby
    Eclair Nov 24, 2015
    kipperbusby , Nov 24, 2015 :
    Every time i unlock my phone, there is a popup message saying "Unfortunately, Setup Wizard has stopped" when i hit "Ok" it just pops up again instantly. this renders my phone useless bc i cant even use it. anyone know the fix?
    #88
  9. Deltastylez
    Donut Nov 24, 2015
    Reflash the rom (wipe : data/cache/dalvik/system)
    Step 1 ; install rom
    Step 2 ; flash gapps
    step 3; wipe cache/dalvik
    reboot system.
    pro tip : do no install Gapps after running the rom.
    #89
  10. kipperbusby
    Eclair Nov 24, 2015
    Thanks! im seeing if that works now.
    #90
  11. NicholasYeo
    Donut Nov 24, 2015
    NicholasYeo , Nov 24, 2015 :
    Thanks guys, did a fresh flash :D All fine now. Thank You so much ><
    #91
    rkiwtir likes this.
  12. GU1LH3RM33
    Step 1 - install rom
    Step 2 - flash gapps
    Step 3 - wipe cache/dalvik
    after reboot system.
    #92
  13. kipperbusby
    Eclair Nov 24, 2015
    is there a way to do this without wiping my phone???
    #93
  14. matssa
    Ice Cream Sandwich Nov 24, 2015
    matssa , Nov 24, 2015 :
    No, not recommended (soft/hard brick)
    #94
  15. killerbee13
    #95
  16. matssa
    Well only for some it seems ^^ But this issue is know, they are currently working on it. It seems to be linked to the toggle between WiFi / Airplane / Data, but they can't seem to find the real solution ^^
    #96
    killerbee13 likes this.
  17. Jaswanth_Reddy_0
    Donut Nov 24, 2015
    #97
    daniel oriakhi 1997 likes this.
  18. BehnanAdam
    Gingerbread Nov 24, 2015
    BehnanAdam , Nov 24, 2015 :
    I don't know which GApps did you flash, but I used this one http://downloadmirror.co/android/ud/open_gapps-arm-6.0-mini-20151113.zip
    There is a smaller Gapps packages, but this one have the Bootwizard app and other needed files for the first boot.
    You may not get mobile data to work directly after first boot.
    Give your OPO a few minutes to settle, and you'll see mobile date working. If not, just restart your phone.
    #98
  19. ArtVandelay
    Froyo Nov 24, 2015
    ArtVandelay , Nov 24, 2015 :
    For everyone having the “No Data Issue” who are using their OPO as a daily driver like me...
    I found this unofficial build on XDA, that already has the no data fix commit that will be included on today’s nightly. Give it a try, it fixed the issue for me. You can dirty flash it over the official cm-13.0-20151124-NIGHTLY-bacon.zip build without any problems.
    What I did:
    1.- Downloaded the file to my phone.
    2.- Turned WiFi off.
    3.- Flashed file via Recovery (Used TWRP 2.8.6.0 fearing it was a modem not flashing situation).
    4.- Wipe Cache and Reboot.
    http://forum.xda-developers.com/showpost.php?p=63980263&postcount=1121
    Kudos and many thanks to XDA member tiny4579 for the build!
    #99
  20. tye359
    tye359 , Nov 24, 2015 :
    lol at everyone saying 'plz help' =D
    guys, you are better off running the unofficial CM13 by Sultan (the 21.11.15 build) as there seems to be far less problems on that one than this nightly by CM. I have been using it for almost a week now.
    jstepa likes this.
