52
ROM Official CM13 nightly builds rolling out for OPO
  1. matssa
    Ice Cream Sandwich Nov 24, 2015
    matssa , Nov 24, 2015 :
    What is the commit that fixes this?
  2. magnamentis
    magnamentis , Nov 24, 2015 :
    that's not the point, if you find it better do it but don't tell others they HAVE TO clean flash if the official cm statement says otherwise. further if you get caught in an errore better say sorry instead of defending you matter of factly false statement. clean installs are always better, that does neither have to be discussed or mentioned. the question is always only if it's mandatory or not and coming from 12.1 it is clearly NOT.
  3. hrishi21007
    Honeycomb Nov 24, 2015
  4. kipperbusby
    Eclair Nov 24, 2015
  5. Deactivated User
    Nov 24, 2015
    ArtVandelay likes this.
  6. rkiwtir
    rkiwtir , Nov 24, 2015 :
    Have flashed the rom, can't comment about the battery as I'm restoring data via titanium backup. Cellular data works fine.
  7. Vadomata
    Jelly Bean Nov 24, 2015
    Vadomata , Nov 24, 2015 :
    Wiping Internal Storage will remove photos, folders and downloaded items.
  8. raiashu92
    Gingerbread Nov 24, 2015
    raiashu92 , Nov 24, 2015 :
    see 2nd point
    http://www.cyanogenmod.org/blog/a-marshmallowy-cm all the modules need to be flashed with it.
    Its better to be safe than sorry. And i NEVER said its mandatory if u read my post. i said its better to clean flash.
  9. wbgrunn
    wbgrunn , Nov 24, 2015 :
    Flashed it; no cellular and no wifi. It is connecting but the state keeps 'saved' instead of connected...
  10. wbgrunn
    Flashed TWRP 2.8.6.0 and now i have wifi but still no cellular. Im trying the fix now..
    Anyone got root working? Adaway does not install and Supersu from Play store does not install the binaries
  11. darushah.shah
    Froyo Nov 24, 2015
    darushah.shah , Nov 24, 2015 :
    There is inbuilt root in dev options. That is working fine.
  12. micemty
    micemty , Nov 24, 2015 :
    today i´ve had the data issue. this here works fine for me. thanks
  13. TheJames
    Jelly Bean Nov 25, 2015
    TheJames , Nov 25, 2015 :
    Really cause those of us around when these forums started, do remember over a dozen kitkat ROMs. It clogged the developer section which each one pinned. That when I really started following developers. Then we got 50mp shots and 64s shutter. Before you were here. I mean its the development community as a whole. I have a ROM for photo taking only. People are and were excited about this device in a way a generic Nexus couldn't gather. OPO is for enthusiast Nexus 5 was for everyday users. And no it came out at the end of 2013 (november) not 2012.
  14. Ak21011989
    Donut Nov 25, 2015
    Ak21011989 , Nov 25, 2015 :
    I Have flashed the official nightly for my OPO using TWRP, Now I have an OTA update for my nightly (Basically from 24th to 25th). In order to update the new nightly, should I update my recovery to Cyanogen recovery or i can stay in TWRP and still get updated via OTA..?
  15. LoneStar144
    Honeycomb Nov 25, 2015
    LoneStar144 , Nov 25, 2015 :
    you can still use twrp. after you download the ota update, boot into twrp, browse to /sdcard/cmupdater, choose the update and flash.
    Ak21011989 likes this.
  16. Ak21011989
    Donut Nov 25, 2015
    Thanks for the response, appreciate it..!
  17. Ak21011989
    Donut Nov 25, 2015
    Does C-Apps support official CM-13 Nightlies..? I tried flashing it, dialer crashes everything else works fine..! Any idea how can we make it work..?
  18. poonam.renu
    Cupcake Nov 25, 2015
    poonam.renu , Nov 25, 2015 :
    • Remove the GoogleDailer.apk and GoogleContacts.apk (ie the one you installed from C-Apps) using Titanium Backup Pro. Make Sure your device is rooted!
    • Reboot your device and finally dirty flash the ROM in TWRP Recovery by wiping Cache and Dalvik Cache only! ;):cool::cool::cool::D
    Will get the stock Marshmallow Dailer and Google Contacts back! The one in C-Apps doesnt support Marshmallow! :cool:
    #TRDownloadz #TRTecH #MarshmallowOnBacon :p
  19. Gio_J
    Donut Nov 25, 2015
  20. Ak21011989
    Donut Nov 25, 2015
    Gio_J likes this.
