52
ROM Official CM13 nightly builds rolling out for OPO
  1. robthorley
    Ice Cream Sandwich Feb 21, 2016
    robthorley , Feb 21, 2016 :
    Switch off 'ok Google' detection from any screen. This worked for me.
    Settings > Google > Search and Now > Voice > "OK Google" detection > From Any Screen
    AntMunny likes this.
  2. AntMunny
    KitKat Feb 21, 2016
    AntMunny , Feb 21, 2016 :
    wow, that really is odd
  3. killerbee13
    Jelly Bean Feb 21, 2016
    killerbee13 , Feb 21, 2016 :
    i am with 21th. All seems working fine, no drain, people can ear me correctly, no bug for now
  4. hrangwala
    Gingerbread Feb 21, 2016
    hrangwala , Feb 21, 2016 :
    I have noticed that in the snapdragon camera the front facing camera looks awful! it has sooo much noise does anyone else notice this?
    gulidelias likes this.
  5. Ricbro
    Ricbro , Feb 21, 2016 :
    Yeah I thought gapps wouldn't effect things like capacitive buttons
  6. gulidelias
    Cupcake Feb 21, 2016
    gulidelias , Feb 21, 2016 :
    Hello, a few days ago I install Cm13.0-20160220 and seems to have a problem with the battery profiles so when I try to switch to power saving mode, the ui stops. and this happens almost every time, but sometimes it doesn't
  7. LCOSTA17
    LCOSTA17 , Feb 21, 2016 :
    You mean yesterday
  8. rb2344
    Eclair Feb 21, 2016
  9. wengezhu
    wengezhu , Feb 21, 2016 :
    Was on 01.30 and it had been pretty stable without major issues, but I am now on 02.21, the battery is going down noticeably faster, I am not sure I can call it battery drain but it is alarmingly close.
  10. Coastie
    Honeycomb Feb 22, 2016
    Coastie , Feb 22, 2016 :
    definitely more drain on 02-21 than there was on 01-29, but still pretty good.
    rontom likes this.
  11. AntMunny
    KitKat Feb 22, 2016
    AntMunny , Feb 22, 2016 :
    Just flashed CM12 feb 22 just because i was bored and my son fell asleep. Full wipe. Coming from Minux31's monthly SlimLP builds.
    Downclocked max and min cpu via kernel adiutor and the values seem to be sticking.
    It's fine. Anticipating approx 4+ hours SOT.
    PrivacyGuard still doesn't automatically apply when you check Enable By Default but I'm nitpicking...
    yogendrang likes this.
  12. yogendrang
    Cupcake Feb 22, 2016
    yogendrang , Feb 22, 2016 :
    Doing the same here but in addition I'm using Lord Boeffla's unofficial one.. I tend to have great usability with that kernel :)
  13. matssa
    Ice Cream Sandwich Feb 23, 2016
    matssa , Feb 23, 2016 :
    Not much changes in the past few days... Can't wait for some major changes, might try out COS13 when it goes out ;)
  14. maulikg
    Cupcake Feb 23, 2016
    maulikg , Feb 23, 2016 :
    Hey is it possible to install the nightly without installing TWRP, I am on CM 12.1 the latest official release? I do not want to format my device hence.. Please advice..
  15. matssa
    Nope you can't, need to wait COS13 if you are on COS12.1.
  16. maulikg
  17. bligus
    Eclair Feb 23, 2016
  18. stefan600
  19. bnw
    Honeycomb Feb 23, 2016
    bnw , Feb 23, 2016 :
    I am on the 22-2 build. When I leave my phone at home on the table for some hours, the battery graph goes almost horizontal (so I think, the Doze feature does a realy good job here!).
    If I lay my phone on my desk at work, the graph goes much quicker to zero (still not bad, but battery consumption whne idling is much more).
    Can that be caused bij a weaker wifi or phone signal or something?
  20. matssa
    Check the phone signal, if it is worse on your job desk then it's the culprit (i have the same thing, I lose a lot of battery on low cell range at my girlfriends house)
