52
ROM Official CM13 nightly builds rolling out for OPO
  1. matssa
    Ice Cream Sandwich Nov 26, 2015
    matssa , Nov 26, 2015 :
    Yes, supersu is still a NO GO, the nightlies are pre-rooted it seems.
    deepakaryan1988 likes this.
  2. Ak21011989
    Donut Nov 26, 2015
  3. lokesh3440
    Honeycomb Nov 26, 2015
    lokesh3440 , Nov 26, 2015 :
    Have you selected MTP from notification panel or its on charging only ?
  4. droblyer
    Cupcake Nov 26, 2015
  5. Rowin023
    Rowin023 , Nov 26, 2015 :
    Thanks for the reply.
    I fixed it by factory resetting and installing the latest Nightly ROM and GApps at the same time without a boot in between (which was the case due to ignorancy last time).
    Everything but cellular data seems to be working fine now. When I turn on airplane mode and then off again, I get celullar data to partially work: an exclamation mark remains.
    I hope this gets fixed with the next Nightly rolling out.
  6. Dhong
    Dhong , Nov 26, 2015 :
    I m on 11/26 nightly and I don't see that option
  7. lokesh3440
    it should be in Settings->Display always.
    Gio_J likes this.
  8. Ak21011989
    Donut Nov 26, 2015
    Ak21011989 , Nov 26, 2015 :
    Yes, I have selected MTP (Transfer Files) option but still it is the same..
  9. Dhong
    Thanks... Got it
    Gio_J likes this.
  10. lokesh3440
    try disconnecting your device from PC once. Connect again and choose MTP. Wait for few minutes. Then open SD card from PC and start copying something onto/from it.
  11. nefty2
    Eclair Nov 26, 2015
    nefty2 , Nov 26, 2015 :
    Is anyone getting a problem where when they plug in their phone, it turns off? I'm at about 2% battery and every time I plug it in, it'll just turn off, but if I turn it on without the charger, it'll stay on.
  12. Ak21011989
    Donut Nov 26, 2015
    will try that and let u know..
  13. hrangwala
    Gingerbread Nov 26, 2015
    hrangwala , Nov 26, 2015 :
    Anyone tested the new 11/26 nightly? Please let us know the bugs and issues. Is it stable? Does data and wifi work?
  14. RedDragon22
    RedDragon22 , Nov 26, 2015 :
    I have installed the nano Gapps with CM13 nightly, can I flash stock Gapps without flashing CM13 again?
  15. lokesh3440
    Yes you can. Wipe system from TWRP advanced menu. Reflash CM 13 without wiping data and then stock GAPPS.
    RedDragon22 likes this.
  16. narc98
    narc98 , Nov 26, 2015 :
    Just installed (looked like it was in a bootloop on splash screen but finished booting in about 2.5 minutes...TWRP 2.8.7, started update from the OTA menu within the ROM). Was having the same mobile data/wifi problems as everyone else on the 25-nightly. Also experienced multiple calls where the other person could not understand anything I was saying (garbled/broken voice...used Hangouts Dialer over wifi and had no issues. Potentially a telephony issue?).
    26-nightly quick notes:
    - mobile data switch on/off does not seem to be fixed (still have to do airplane mode fix)
    - my phone call clarity appears to be resolved
    TWRP: 2.8.7
    ROM: 26 Nov-nightly (clean install on 25-Nov nightly after using resurrection rom)
    Gapps: nano
    hrangwala likes this.
  17. Ak21011989
    Donut Nov 26, 2015
  18. matssa
    Uggg... For the third time, not support on CM13, you need to wait an update.
    Please, read the other posts or use the search button...
  19. Vadomata
    Jelly Bean Nov 26, 2015
  20. crazyniko
    crazyniko , Nov 26, 2015 :
    I have problem with data connection/modem,
    someone had the same problem and how to solve ? thank you
