13
Official COS13 ZNH0EAS26M is out
  1. lazloinsf
    Froyo Apr 10, 2016
    lazloinsf , Apr 10, 2016 :
    ok, many hrs later am back to where I should be...
    anyone else getting "Package Updater Has Stopped" on install of 3rd-party (non-GoogPlay) apps??? have a forced LookOut scan before install in chain which works fine, then shows install and permissions screen, then install screen, then error message -- apps seem to have installed fine regardless ... very weird...
  2. justinb928
    Ice Cream Sandwich Apr 10, 2016
    justinb928 , Apr 10, 2016 :
    Only issue for me is that my service keeps going in and out with no LTE. Anyone know a fix? I feel like this has happened to me before.
  3. Zouille
    Donut Apr 10, 2016
    Zouille , Apr 10, 2016 :
    Hello,
    I Update my OPO with incremental, it was ok but I've à probleme.
    When I go to battery settings, I've an error message : settings stop.
    What can I do
    Thank you
  4. lazloinsf
    Froyo Apr 10, 2016
    Well, there were all sort of issues in 12 where you had to wipe all the APNs, let them reload from SIM (or manually create one w/ correct params), Airplane-Mode on / off, reboot, swing a chicken in the air over your head, throw your cat against the wall, etc.... if you look back in the forum archives on 12 series of updates there are all sorts of posts that might help...
    Or, CM13 / A6.0 introduces intense "Doze Mode" to save battery charge -- you have to do Settings : Battery : 3-dots (upper right corner) : Battery Optimization : All (dropdown) : Each App You Want To Stay Awake -- to get to it and have no clue if it actually works, on my Xperia Z4 tab which has been on 6.0 for 2 wks now it seems to be ignoring most of what I have attempted to reset...
  5. shubhamgupta659
    Donut Apr 10, 2016
    shubhamgupta659 , Apr 10, 2016 :
    google drive link for incremental update plz... for me google drive have good download speed .. thanks in advance :)
  6. Mijo Bažoka
    Honeycomb Apr 10, 2016
    Mijo Bažoka , Apr 10, 2016 :
    Dude, if he doesn't have root, then Flashify is useless.
    You need PC to flash TWRP, and TWRP to flash SuperSU 2.XX to get root.
  7. Mijo Bažoka
    Did you use the correct SuperSU version?
  8. smoins786
    Eclair Apr 10, 2016
    smoins786 , Apr 10, 2016 :
    Greatttt...
    Hope 13.1 comes soon...
    How is your battery life on cos 13??
    Here is some weird thing happening to me
    Even though my WiFi is turned off it is running in the back ground..
    You can see it in the screen shot
    And my battery is draining out really fast
    What to do :/
  9. nobert07
    Gingerbread Apr 10, 2016
    nobert07 , Apr 10, 2016 :
    guys i downoaded the zip and updated through cyanogen recovery .. update finished but the device is still in start screen after optimizing the apps... Pls help
  10. nobert07
    guys after applying the update the apps were optimizing and the phone rebooted but it is still in start screen.. I dint do any backup.. pls help me
  11. l3dz3pp
    Cupcake Apr 10, 2016
    l3dz3pp , Apr 10, 2016 :
    I'm still having the microphone issue, even with this CM13. I think I have to buy another phone... :((
  12. lokesh3440
    lokesh3440 , Apr 10, 2016 :
    Same for me too. Battery drains extremely fast even after 3 charging cycles. I even saw phone heats up doing casual browsing. Fortunately there are no lags.
    smoins786 likes this.
  13. daniga74
    Jelly Bean Apr 10, 2016
    daniga74 , Apr 10, 2016 :
    Did you disabled wifi scan and bluetooth scan in localization settings?
  14. daniga74
  15. lokesh3440
    Yeah it's disabled.
  16. MakaG
    MakaG , Apr 10, 2016 :
    Order a new mic over aliex**** for 7,8€ with free shipping to europe and change it by your self with a little help for a youtub video in cca 30min an it will be just like new. at least thats what i did... ;)
    vrbljani likes this.
  17. l3dz3pp
    I won't do that. It's clear that it's a software matter, cos if I turn off OKGoogle on any page, everything is OK.
    MakaG likes this.
  18. travishb2
    Eclair Apr 11, 2016
  19. Harshit09
    Gingerbread Apr 11, 2016
    Harshit09 , Apr 11, 2016 :
    You need to be on the stock recovery. I have the same problem. So I can't update yet.
  20. Harshit09
    Wait for some time and flash the official one. They'll probably release it after they roll out OTAs.
