10
ROM [OFFICIAL] [DIRTY UNICORNS] [OP2]
Thread Status:
Not open for further replies.
  1. Cool Droid
    Ice Cream Sandwich Jul 17, 2016
    Cool Droid , Jul 17, 2016 :
    No kcal settings present in ROM by default. You should flash anything else (other than ROM and GApps) always after the first boot, it's written in the OP.
    #41
  2. christopher78
    Honeycomb Jul 17, 2016
    christopher78 , Jul 17, 2016 :
    I know it's for this reason that i asked this because on the boeffla website it's says that it's recommanded to flash rom and kernel after anyway thanks :)
    #42
  3. Cool Droid
    Ice Cream Sandwich Jul 18, 2016
    Cool Droid , Jul 18, 2016 :
    New build is up (~˘▾˘)~
    Get it here.
    - SmartBar: fix bar alpha when pulse enabled and music paused from lock
    - Pulse 2.0 Advanced Audio/Visual Rendering
    - Add CPU info overlay
    - Remove navigation bar option in Extended desktop settings
    - Adjust padding between battery icon and text
    - Make sure screenshot's QS and power menu icons match
    - Get rid of ugly dialog in radio info
    - Fix volume timeout
    - Fix Gallery's progress bar stay at 0 when play some clips
    Device specific changes :
    - Largely improved camera performance
    - Fixed many SELinux denials
    - Boot-up time improved
    - Improved translations
    If you're already on 07/09 build, dirty flash will work but if any build earlier than that, clean flash is highly recommended.
    Official Note : Clean flash is always recommended.
    Have to write XD :D
    #43
  4. Rushabh Gohel
    Jelly Bean Jul 18, 2016
    Rushabh Gohel , Jul 18, 2016 :
    Clean flash recommended or dirty flash is fine.
    #44
  5. Cool Droid
    Edited the post ;)
    #45
    Rushabh Gohel likes this.
  6. Rushabh Gohel
    Yes I am on 7/9 build so, I am good with dirty flash..:p
    #46
  7. christopher78
    Honeycomb Jul 18, 2016
    christopher78 , Jul 18, 2016 :
    Cool thanks
    I have one question, how did you do to have a good battery life, on RR i had a just 2h30 SOT(from 100% to 5%) using Greenify, Amplify,Better Battery Stats, and i tried to calibrate the battery,
    I gonna clean flash the latest build what would you recommand me to do to have a good battery life like you ?
    #47
  8. Cool Droid
    I personally didn't use any app for battery stuff, neither any kernel. Just let the ROM settle down, don't look out for good SOT from day one. If still you're having bad battery life with normal-to-heavy usage then blame your apps, check their wakelocks and turn them off. You can get some pretty good normal and kernel wakelocks guides on XDA.
    #48
    christopher78 likes this.
  9. Cool Droid
    Ice Cream Sandwich Jul 19, 2016
    Cool Droid , Jul 19, 2016 :
    Yo bois (and gals if there :p)
    Prettified the thread and added one more opening post which will have certain guides. Because of character limitation in posts on forums, only the latest two changelogs will be provided in OP (no space for more lol). Whenever a new build comes there'll be a post for it with it's changelog and notes (if required) so be sure to read those posts.
    And to everyone here coming for first time, please go through the thread once, it may happen that the question you have is already answered. If you still have query to such question, feel free to PM me. New questions and stuff is always welcome in the thread.
    #49
  10. coolmohit31
    Honeycomb Jul 19, 2016
    coolmohit31 , Jul 19, 2016 :
    Wow.. The thread really looks good
    Great job
    #50
  11. Cool Droid
    Ice Cream Sandwich Jul 25, 2016
    Cool Droid , Jul 25, 2016 :
    Get it here.
    - New DU logo ALL THE WAY
    - Pulse: Set upper limit of 40 FPS on renderer drawing
    - Solid Bar Sanity Levels, Lavalamp Speed, and Sliders
    - Disable cellular networks settings menu if airplane mode is enabled
    - Settings: Add ProximityWake -Update AdBlocker hosts source and files
    - Translation updates
    - AOSP upstreams
    - GPS overlays added for faster fix
    - Bluetooth instabilities fixed
    Notes : Thread also updated with new DU logo :cool:
    #51
  12. Lancelot_69
    Lollipop Jul 28, 2016
    Lancelot_69 , Jul 28, 2016 :
    Finally installed last night!
    #52
  13. Lancelot_69
    #53
  14. Lancelot_69
    #54
  15. Cool Droid
    Ice Cream Sandwich Jul 29, 2016
    Cool Droid , Jul 29, 2016 :
    You had uninstalled Android System Webview? I totally assume that as you said e-mail. So, if yes, never ever uninstall ASW because it is responsible for providing you the instances of web in your mobile apps whenever you're doing the sign-in and processes like that. If you did a dirty flash then okay, otherwise without ASW one cannot even sign-in into Google account.
    #55
  16. Lancelot_69
    Lollipop Jul 29, 2016
    Lancelot_69 , Jul 29, 2016 :
    I never uninstalled, it never came with anything. I did clean flash, flashed DU then gapps, booted then flashed supersu. Finished install, loaded other apps. Everything was crashing, then googled problem, I had to install android Web viewer.
    #56
  17. christopher78
    Honeycomb Jul 29, 2016
    christopher78 , Jul 29, 2016 :
    Hello i'm on latest build(i dirty flahsed from 15/07) and 2/3 of the times when i want to unlock my phone with the fingerprint scanner, it's says "fingerprint hardware not available, the home button works and i tried to reboot and to wipe cache and dalvik but still have the same problems. The fingerprint scanner works just works 1/3 of the times and it happened today and i didn't had this problem when i flashed the rom on the 24/07
    Could someone help me please ?
    #57
  18. Cool Droid
    Ice Cream Sandwich Jul 31, 2016
    Cool Droid , Jul 31, 2016 :
    Get it here.
    - Boot time reduced (yay :cool:)
    - WiFi QS bug fixed
    - Upstreams from CM
    #58
  19. Cool Droid
    Ice Cream Sandwich Aug 6, 2016
    Cool Droid , Aug 6, 2016 :
    Build bumped up to latest Official v10.5, get it here.
    - Lots of translations
    - Update to Android-6.0.1_r62
    - New DU logo for QS navbar/fling tile and keyboard
    - Added revert recents in OmniSwitch
    - Bring back basic group support
    - Enable support for groups in External contacts accounts
    - Sync citylist handling with upstream in DeskClock
    - Fix crash when no storages are available
    - Fix concurrent access to mStorages
    - Disable all ListView and GridView selectors in OmniSwitch
    - New DU logo everywhere
    - Added ability to change location sensors mode in quick settings
    - Added Solid bar sanity levels and Lavalamp anim speed
    - Fix lock insanity with ActivityManager
    - Fix and remember state with OmniSwitch's launcher mode
    - Allow immersive options for Slim Recents
    - Move LockClock up per request
    - Fix notification panel can't hide in statusbar
    - Enable camera hal v3 interface
    - Set upper limit of 40 FPS on Pulse's renderer drawing
    - Added Proximity wake on selected devices
    - Fixed NPE in Messaging app
    - Add tabs transitions effects in DirtyTweaks
    - Add a blank footer to System app remover
    - Add ability hide/show app launcher icon for OmniSwitch
    - Make sure screenshot Qs and power menu icons match
    - Fix volume timeout derp
    - Add backup services to the whitelist after the android-6.0.1_r54 merge
    - Remove navigation bar option in Extended desktop settings conditionally
    - Fix SmartBar alpha when pulse enabled and music paused from lockscreen
    - Update DU Certified to v2.3
    - Battery backup improvements
    #59
  20. NooBs7yL3
    Gingerbread Aug 9, 2016
    NooBs7yL3 , Aug 9, 2016 :
    Hi, would try this Rom but before I like to know how is the Rom in terms of stability, battery, GPS (read that some roms had problems) and camera.
    #60
