10
ROM [OFFICIAL] [DIRTY UNICORNS] [OP2]
Thread Status:
Not open for further replies.
  1. Rushabh Gohel
    Jelly Bean Aug 9, 2016
    Rushabh Gohel , Aug 9, 2016 :
    Everything is good, Go with it but I noticed that when day pass battery life getting low.
    Other than that everything this good.
    #61
    NooBs7yL3 likes this.
  2. Cool Droid
    Ice Cream Sandwich Aug 14, 2016
    Cool Droid , Aug 14, 2016 :
    New build is up (~˘▾˘)~
    A major one here, nice set of changes, get it here.
    - Fling: Trails width configuration
    - SlimSeekBarPreference refactor
    - Display bluetooth battery status when available
    - Fling: update android-trail-drawing from Orange Open Source to 1.2.6
    - Themes: Misc fixes that came in with CMSDK refactor
    - Make overlay permission check configurable
    - Gallery2: rework photo page layout
    - Security fixes
    - Translation updates
    Device specific changes :
    - Dexpreopt is back (Faster boot time)
    - Added SIO
    - Tweaked Interactive
    - Improvments to WLAN section
    - Added Snap Camera
    - Added switch to disable H/W keys
    - Tweaked power optimizations
    - Fixed Doze not kicking-in after intensive work
    Clean flash is recommended.
    #62
  3. Cool Droid
    Ice Cream Sandwich Aug 21, 2016
    Cool Droid , Aug 21, 2016 :
    Get the build here.
    - Gallery2: add slideshow delay setting
    - Themes: Add missing exposures and separate power dialog icons
    - QsTiles: Configurable Themes tile components to apply
    - DocumentsUI fixes
    - Applied workaround for MultiSelectListPreference bug
    - Allow fast charging at 2A
    - Raise chargerlimits
    - Enable KCAL support
    - Upstreams from CM
    - Fixed a music player bug where automatic change of track freezed the player
    - Added Snap camera from CM13
    • Fast charging is enabled by default, device will charge at 2A instead of 1.5A.
    • KCAL support added in stock kernel, so you just need Kernel Adiutor to tweak it.
    #63
    Jibin Philipose likes this.
  4. Cool Droid
    Ice Cream Sandwich Aug 29, 2016
    Cool Droid , Aug 29, 2016 :
    Get the build here.
    - Fixed low audio recordings
    - Rotation sensor working fine now
    - Squashed out Random Reboots
    - GPS stability improvements
    - Added SIM disable switch (null SIM icon disappears too now)
    - Added Proximity wake flags
    - Minor bug fixes
    #64
  5. Lancelot_69
    Lollipop Sep 8, 2016
    Lancelot_69 , Sep 8, 2016 :
    Running 10.4 DU everything is fine until today. I was having issues with connecting to wifi so I rebooted, phone comes on and everything is reversed! On the screen everything that was on the right side off screen is now on the left and vice versa. Open up Google playstore everything is reversed. It is fricken weird, tried reboot, hot and normal. Can't upgrade at work because I need to use phone until I get home. Any ideas?
    #65
  6. christopher78
    Honeycomb Sep 8, 2016
    christopher78 , Sep 8, 2016 :
    Did you try to reboot in safe mode to see or to clear cache and art cache?
    Otherwise wait to get back home to clean flash the rom or do what you think you should do
    #66
    Lancelot_69 likes this.
  7. Lancelot_69
    Tried all of the above. Scanned with malware bytes, Antivirus. Good news is everything works, phone calls, emails, data will connect and work but wifi won't. Then there's also the everything is backwards issue which will mess me up for the next 5 hours lol. Will flash 10.5 when I get home if I have too.
    #67
    christopher78 likes this.
  8. Lancelot_69
    #68
  9. Lancelot_69
    #69
  10. Lancelot_69
    Lollipop Sep 9, 2016
    #70
  11. Nuhro
    Eclair Sep 14, 2016
    Nuhro , Sep 14, 2016 :
    Guys, one question. I hope you dont kill me for that :D
    Why is DU unofficial and not official, what are the differences and what are the advantages and disadvantages?
    Thanks
    My english is not the best, i know. Sorry for that...
    #71
  12. Cool Droid
    Ice Cream Sandwich Sep 16, 2016
    Cool Droid , Sep 16, 2016 :
    Get it from here.
    - Update to Android 6.0.1_r68
    - Lots of translations
    - Configurable Themes tile components to apply
    - Switch to HTTPS for our updater
    - Add missing exposures and separate power dialog icons
    - A lot of Gallery2 improvements/fixes
    - Rewrite DU-About a little
    - Fix lockscreen charging current switch
    - Statusbar icons transparency
    - A lot of FMRadio improvements/files
    - Refactor SlimSeekBarPreference
    - Expose new hard coded colors for themes in Messaging
    - Add vector image and fix themeing issue in Messaging
    - Fling trails width configuration
    - Update bcm4356 FW
    - Use HTTPS when fetching changelogs
    - DocumentsUI fixes
    - Account for time changes when showing recent activities
    - Increase max screen recording time to 1 hour
    - Allow force landscape mode with screenrecord
    - Bump DU Certified to 2.4.1
    - Misc CMTE fixes that came in with CMSDK refactor
    - Update Fling library from Orange Open Source to 1.2.6
    - Added hardware key disable support with M adaptations
    - OmniSwitch: launcher: change essentials launch intents
    - OmniSwitch: revert recent apps should not change order in quick switcher
    - OmniSwitch: no ripple no fun
    - Fix Slim Recents unknown window type error
    This is the last build we're getting of DU 10 (Marshmallow), hope it was a good time for y'all using it :)
    The DU team has already started working on DU 11 (Nougat) and if someone wants a track then can follow their G+ community or Gerrit.
    Will see y'all with DU 11, have a nice time :D
    #72
    jansvanda and Lancelot_69 like this.
  13. jansvanda
    Honeycomb Nov 6, 2016
    #73
  14. locxFIN
    KitKat Nov 6, 2016
    #74
    jansvanda likes this.
  15. jansvanda
    #75
  16. locxFIN
    KitKat Nov 6, 2016
    locxFIN , Nov 6, 2016 :
    So, there you have the news. It's coming, now let's be patient.
    #76
  17. locxFIN
    KitKat Dec 13, 2016
  18. Cool Droid
    Ice Cream Sandwich Dec 13, 2016
    Cool Droid , Dec 13, 2016 :
    Nothing better than this GIF to make the thread alive again...
    Dirty Unicorns 11.0, first official test build: Let's get dirty again!
    Devs-Base Thread: Click Me
    - Oh well, what are you here for? You need to be dirty enough to know the changelog. Flash that and get dirty :rolleyes:
    Known bugs: Button backlight cannot be disabled, fix in OP might work
    #78
    Lancelot_69 and locxFIN like this.
  19. jeepers007
    Donut Dec 20, 2016
    jeepers007 , Dec 20, 2016 :
    Looks like the link is dead. Build was pulled I guess....
    #79
  20. locxFIN
    KitKat Dec 28, 2016
