248
ROM [OFFICIAL][LINEAGE OS/CM14.1][ONEPLUS2] [DISCUSSIONS][DOWNLOADS]
  1. DarkNounours
    Froyo May 27, 2016
    DarkNounours , May 27, 2016 :
    We are many to wait for OOS sources release for OP2 so that CM13 could become the one rom to rule them all :eek:
  2. dinjesk
    KitKat May 27, 2016
    dinjesk , May 27, 2016 :
    By the time they release its time to upgrade to the new op3 lol
    Vector and wedad like this.
  3. masaga91
    Gingerbread May 28, 2016
    masaga91 , May 28, 2016 :
    I honestly don't think they'll release it any time soon, maybe after they release oos3 update
  4. dinjesk
    KitKat May 28, 2016
    dinjesk , May 28, 2016 :
    think they will release it on the same day. OP3 will come with OOS3.1 out of the box
  5. johndoethedog
    Cupcake May 28, 2016
  6. Fikri
    Fikri , May 28, 2016 :
    Maybe a N00B question but I can't find the answer in the thread. Is it possible to flash thist nightly version of garacks?
    I just upgraded tot the OS community build but I'm not satisfied wit Oxygen.
    I expect to do a factory reset again, is it possible to install this version from SD? or do I have to root?
  7. TheZaaz
    Froyo May 28, 2016
    TheZaaz , May 28, 2016 :
    Hey guys, I have a few questions.
    I installed the Rom before I installed the SUPER sure package, so my phone isn't rooted. Do I need to wipe before I install supersu to root? Or can I just root anytime?
    Also my phone incessantly vibrates while I'm on a call. It's not happen feedback and there's no pattern. It just seems to vibrate randomly.
  8. redlinecoatings
    Ice Cream Sandwich May 28, 2016
    redlinecoatings , May 28, 2016 :
    Root is built into the ROM, just enable in developer options. As for the vibrating, it's a proximity sensor thing. If you put the phone tight to your ear it'll stop. Also I've read that turning off double tap to wake makes it stop.
  9. TheZaaz
    Froyo May 29, 2016
    TheZaaz , May 29, 2016 :
    Okay cool. Thanks so much for the info!
  10. smrdelj
    Gingerbread May 29, 2016
    smrdelj , May 29, 2016 :
    i wish..
    Its quite a pity that fps works badly (it really fails a lot). If not, kristofs build would be perfect
    And what about grarak? Disappeared
    dinjesk likes this.
  11. dinjesk
    KitKat May 29, 2016
    dinjesk , May 29, 2016 :
    Thought garak is quite busy with exams.
  12. neelansh13
    Froyo May 29, 2016
    neelansh13 , May 29, 2016 :
    Nope. Will change rom in some days time.
  13. JelleZon
    OnePlus Accessory Tester May 29, 2016
  14. sparse Gupta
    Froyo May 30, 2016
  15. ant_mir
    Honeycomb Jun 2, 2016
    ant_mir , Jun 2, 2016 :
    I tried. I installed and sound was good, camera was good, speed was good. But I couldn't make a single call it just "crashed" everytime I tried!
    I did 3 clean installs with 3 gapps (micro, nano and stock). All of them failed. I'm back to OOS 3.0.1.
    sparse Gupta likes this.
  16. THE_KINGDOM
    Gingerbread Jun 2, 2016
  17. ant_mir
    Nevermind. O forgot to install 5.1.1 firmware and calls dos not work.
  18. 13dillion
    13dillion , Jun 2, 2016 :
    USB OTG? ... I've not had any problems with OTG using Graraks ROMs.
    (... once I bought the official OP adapter)
  19. casep
    Donut Jun 2, 2016
    casep , Jun 2, 2016 :
    Hi, I saw the same problem. For me the solution was setting the default Phone app
    https://forum.cyanogenmod.org/topic/124381-dialer-crashes/#comment-590388
    So far Working OK for me.
    Kind regards
    dinjesk and ant_mir like this.
  20. gopinathr
    gopinathr , Jun 2, 2016 :
    Do hybrid twrp v2 work to flash Garak's cm13 rom. Or let me know the proper twrp file compatible with this.
    I managed to flash it correctly with this modified twrp (no errors).
    But, it got stuck in boot logo (I waited for 10 mins or so) and then went back to oos.
