248
ROM [OFFICIAL][LINEAGE OS/CM14.1][ONEPLUS2] [DISCUSSIONS][DOWNLOADS]
  1. dheeraj9x
    Froyo Dec 18, 2016
  2. arminth
    Honeycomb Dec 18, 2016
    arminth , Dec 18, 2016 :
    What a helpful post showing your dedication and deep knowledge of the subject!
    PLONK!
    Armin
    burnout123 and pppttl like this.
  3. cirillo30
    Gingerbread Dec 18, 2016
    cirillo30 , Dec 18, 2016 :
    it is a known bug?
  4. cirillo30
  5. Santi_SAZ
    Santi_SAZ , Dec 18, 2016 :
    No issues with Bluetooth at my end
  6. ArtuCer
    ArtuCer , Dec 18, 2016 :
    The same issue for me. The phone doesn't work if Bluetooth is conected to the car radio. I have been updated modem firmware when was installed H2OS 2.5.1.
  7. Santi_SAZ
    Did you have issues before update modem firmware?
    I use Sony SBH50 headphone and never had issues with Bluetooth with CM14.1 even CM13
  8. ArtuCer
    Before installing H2OS 2.5.1 I don't have this issues with CM14.
  9. niki2002
    Cupcake Dec 18, 2016
    niki2002 , Dec 18, 2016 :
    I just got android 7.0 and ever since all my apps take. Forever to load and some don't even work also one time my phone screen turned black and I couldn't do anything except turn the phone off blindly ( I have a one plus 3)
  10. ShortyEx
    Ice Cream Sandwich Dec 18, 2016
    ShortyEx , Dec 18, 2016 :
    Maybe you should post this in de OP3 forums and if you do, also be more specific over the OS you are running.
  11. moffe79
    Eclair Dec 18, 2016
  12. Jinx
    Froyo Dec 18, 2016
    Jinx , Dec 18, 2016 :
    Can't search this thread on mobile but are there no manual camera controls? Currently on the Nov 30th build.
  13. gaster
    Moderator Moderator Dec 18, 2016
    gaster , Dec 18, 2016 :
    What's the current status? Does the nightly last build acting pretty stable for a daily use? Also how is the camera?
  14. Santi_SAZ
    Then you know what's the matter.
    Try to return to OOS modem firmware
  15. Santi_SAZ
    Is stable, you can use as daily driver.
    Camera works fine, I didn't try video but I think is working properly.
    gaster likes this.
  16. Deactivated User
    Dec 18, 2016
  17. ShortyEx
    I did notice cellular reception via Bluetooth built-in car kit is a bit irregular when just connected and the phone is asleep. If I wake the phone up or receive a call, the problem fixes itself.
  18. gaster
    Thanks for the feedback friend. Appreciated
    Santi_SAZ likes this.
  19. MasterJam
    MasterJam , Dec 18, 2016 :
    Ist ScreenMirroring working for you guys?
    With StockRom this was no problem at all, but with CM the connection instantly fails after TV connects to the phone.
  20. Sothis6881
    Eclair Dec 19, 2016
    Sothis6881 , Dec 19, 2016 :
    Also having problems with the camera, but only the updated version from the Play store. Rolling back to a previous version works fine.
