248
ROM [OFFICIAL][LINEAGE OS/CM14.1][ONEPLUS2] [DISCUSSIONS][DOWNLOADS]
  1. mido25
    Ice Cream Sandwich Mar 24, 2016
    mido25 , Mar 24, 2016 :
    Yes. I did experience that.. It needs kernel sources I believe. Looks like we have to live with that till OOS releases their kernel sources.
  2. wolf35
    wolf35 , Mar 24, 2016 :
    Just install the zip via TWRP and you're done. No worries about new installation with a dirty flash! I
  3. Marco Snippe
    Honeycomb Mar 24, 2016
    Marco Snippe , Mar 24, 2016 :
    this is not the question of what works with you or not the point is if you are new to cm13 or cleanflashing and you get this error there will be questions. So if you install the latest opengapps you will get the error ok google stopped working.
    reboot to recovery (twrp) press install then the latest build you want to flash done.
    Do not reboot!!!!!!!!
    Then again install then press supersu let it install then reboot
  4. mido25
    I do not know if latest Opengapps break some functionality. I'm using feb 22nd version.
    Some people said, installing gapps mini solved all their issues with on tap and Google now. You can try that if you are planning for a clean flash.
  5. Jabrnet
    Gingerbread Mar 24, 2016
    Jabrnet , Mar 24, 2016 :
    deviantartjr likes this.
  6. mido25
    Can you move away from router 50m or something(makes more sense if you are seperated by a wall or something) and try to post the result?
  7. Deactivated User
    Mar 24, 2016
  8. KingKaan
    Froyo Mar 24, 2016
    KingKaan , Mar 24, 2016 :
    I'm runnig Seraph08 ROM too and i'm considering to flash graraks build. can you tell me if dirty flashing graraks rom over seraph08s rom works without any problems?
  9. mido25
    should not give any issues. Better to take a nandroid. Just in case...
    KingKaan likes this.
  10. nitramcek
  11. sebobalci
    Eclair Mar 24, 2016
    sebobalci , Mar 24, 2016 :
    I May not have a superfast internet connection but Wifi is ok for me. My lan result on desktop was 85.9 for downloading en 6.91 for uploading. So you can make a comparasion.
  12. Jabrnet
    Oh I was 2 floors up from my router in the basement. You can see I don't even have full WiFi signal there. It is an AC router though on 5ghz signal.
    mido25 likes this.
  13. 13dillion
    13dillion , Mar 24, 2016 :
    Wiped system, data and caches, flashed new build, pico gapps and SU. Phone now unencrypted and latest ROM is looking good and behaving well. Still experiencing some WiFi drops (no worse than before).
    All good here - thanks for the updated ROM. :)
  14. mactoni
    Jelly Bean Mar 24, 2016
    mactoni , Mar 24, 2016 :
    Right! It was the same for me..with the nano version. Then i re-flashed the stock and it worked
  15. mido25
    Well, Issue is with 2.4GHz frequencies. You're lucky :)
  16. Wackencorpse
    KitKat Mar 24, 2016
    Wackencorpse , Mar 24, 2016 :
    Should be no problem. I came from Graraks with a dirty flash and will now dirty flash again Graraks. Everytime I flash a new build I do a nandroid backup if something went wrong.
  17. 13dillion
    Does anyone else get a FC when opening the clock app?
    EDIT: - forget the above, it was related to the Infamous Theme. I've removed the theme, and can access the clock app ok now.
  18. Ankit Antony
    Cupcake Mar 24, 2016
    Ankit Antony , Mar 24, 2016 :
    I won't haha... And if I'm stuck in a bootloop, I can easily get myself out... I've had experience... My question was what's the max speed the processors can run at? (Oc'd)
  19. mido25
    1.7 Ghz for A53
    2.0 Ghz for A57
  20. sandeeppaleri
    sandeeppaleri , Mar 24, 2016 :
    Flashed the latest build.. It's been couple hours now.. I don't know if it's just me but I'm experiencing heavy battery drainage..does anybody else have the same problem..?
