248
ROM [OFFICIAL][LINEAGE OS/CM14.1][ONEPLUS2] [DISCUSSIONS][DOWNLOADS]
  1. matt_simpson
    Ice Cream Sandwich Mar 31, 2016
    matt_simpson , Mar 31, 2016 :
    You wont have root unless you enable it in developer options.
  2. mido25
    mido25 , Mar 31, 2016 :
    My bad it's 2.2.1 post edited
  3. Deactivated User
    Mar 31, 2016
  4. mido25
    I dirty flashed this build over my old one and it worked. I honestly have no idea about the error as I'm not the dev. Can't you try dirty flashing this build on top of the last one?
  5. Foggy79
    Gingerbread Mar 31, 2016
    Foggy79 , Mar 31, 2016 :
    Yes
  6. Deactivated User
    Mar 31, 2016
  7. patel lav
    patel lav , Mar 31, 2016 :
    dirty flash is not working for me it shows error.
    what can i do ?
    how to update my cm 23/3 to 30/3?
  8. drrishabh
    drrishabh , Mar 31, 2016 :
    it looks like it has all the qualities needed to be an official CM rom for
    OPT (y) Great Job guys.
  9. spysky
    spysky , Mar 31, 2016 :
    This is something that is bugging the sh*t out of me, why is it allowing some users to dirty flash and not others?
    Is it something to do with the recovery each one of us is using?
    I'm currently using twrp-3.0.0-1, and it's failling the dirty flash.
  10. mido25
    If it gives issues please stay in last build. I do not know what went wrong for you.
  11. Deactivated User
    Mar 31, 2016
  12. mido25
    I was on old twrp btw.
  13. mido25
    Just follow the unbrick guide. You can see Matt's post. And make phone boot. Continue in previous build until he finds a way. Thanks a s sorry for what happened to you.
  14. Deactivated User
    Mar 31, 2016
  15. mido25
    Which twrp worked for you?
  16. spysky
  17. mido25
    spysky likes this.
  18. Deactivated User
    Mar 31, 2016
  19. mido25
    Glad to hear that worked for you. If you can update the steps, I'll put it in OP. Thanks for not giving up :)
  20. Foggy79
    I dirty flashed with TWRP 3.0.0.2 from the previous build. Only wiped cache. Worked for me.
