248
ROM [OFFICIAL][LINEAGE OS/CM14.1][ONEPLUS2] [DISCUSSIONS][DOWNLOADS]
  1. Ankit Antony
    Cupcake Apr 8, 2016
    Ankit Antony , Apr 8, 2016 :
    while flashing the april 02 build i get an error at 57% saying zip file is corrupt!!!! help
  2. Tricksodave
    Jelly Bean Apr 8, 2016
    Tricksodave , Apr 8, 2016 :
    @mido25 trying to install the latest build, coming from 30th march build. Getting the error 7 code in twrp. Tried following your steps, by flashing OOS.
    I still receive the error after flashing OOS. Any ideas.
  3. Symphy
    Ice Cream Sandwich Apr 8, 2016
    Symphy , Apr 8, 2016 :
    Can i flash the lastest build 2nd avril from the 23th march ? Or do i have to flash 30th march and then the 2nd avril ?
  4. matt_simpson
    matt_simpson , Apr 8, 2016 :
    yes you can flash
    Symphy likes this.
  5. mido25
    mido25 , Apr 8, 2016 :
    Wipe everything except internal memory, flash 5.1.1 fw and try to flash build again
  6. mido25
    Corrupted zip file. Download again
  7. Gizmokid2005
    Eclair Apr 8, 2016
    Gizmokid2005 , Apr 8, 2016 :
    I've run into another issue. Logging in to the Simple Banking app black screens the device requiring a subsequent long press to revive the device. I'm unable to successfully login.
  8. dinjesk
    KitKat Apr 9, 2016
    dinjesk , Apr 9, 2016 :
    sources has been released for the lollipop version of oxygen.
    just wait for oxygen MM the be official and the will release sources
    hampfred likes this.
  9. mido25
    Ice Cream Sandwich Apr 9, 2016
    mido25 , Apr 9, 2016 :
    Banking apps always had issues with rooted phones and custom Roms. Maybe that's why.
  10. Ankit Antony
    Cupcake Apr 9, 2016
    Ankit Antony , Apr 9, 2016 :
    Yes you're right... Betrayed by my own network... It didn't install completely... About 40mb missing... Thanks anywaus
  11. pendragon
    Gingerbread Apr 9, 2016
    pendragon , Apr 9, 2016 :
    I'm running this image for a few days now. I love it, but have one issue, bluetooth. When connected to my car it all looks ok, I make a call, works fine, I hangup, call again and the phone turns dead, no screen, nothing. The only way to fix this is push the powerbutton and do a hard reboot. Anyone else having this issue or maybe a solution for this?
  12. mido25
    Depends on your car model. I've seen guys reporting no issues with the sync and connection with the car. How OOS treating you in this scenario?
  13. pendragon
    OOS (but not MM) worked fine with my bluetooth. I have a VW branded car with the new RNS510 MIB. I'm going to check if there is a bluetooth update for this unit or else I have to go back to 5.1......but I hope I don't have to, because I love this ROM! and I've always prefered CM over OOS. I also have a OPO and still lovin CM on that one as well.
  14. gaz_0001
    Froyo Apr 9, 2016
    gaz_0001 , Apr 9, 2016 :
    I just downloaded the latest Grarak Cm13.
    How do i disable the second sim?
    I have two sims installed, but i only enable the 2nd one occasionally.
    I like to have it disabled most of the time to have the status bar more tidy and also save battery.
    Cheers
  15. pendragon
    I've done some test and the conclusion is a bit strange, but it's the combination OPT with the flap case. When I have my phone 'open' I see that the screen turns on and everything works fine. I can call as many times as I want without the phone crashing. As soon as I close the phone with the flapcase the phone crashes when I try to call. Maybe the reason why is because the screen will not turn on when the cover is closed? I have not idea what the reason for this is.
  16. mido25
    Unfortunately, we do not have that option in cm now. It's broken. In cm, grarak removed the option.
    But in AOSPB ROMs like tipsy, tesla and exodus, option is present but they are broken.
  17. mido25
    LOL I bet that has something to do with proximity sensor. Do one thing, in display tab, check prevent accidental wakeup option. It may help.
  18. hampfred
    hampfred , Apr 9, 2016 :
    I don't think its possible to disable one sim.
  19. Ankit Antony
    Cupcake Apr 9, 2016
    @mido25 help please!!! i can't seem to be able to flash 2.2.1 ota from 2.1.2 (totally unrooted and with stock recovery)... While installing the update, the progress bar just stays at the beginning, doesn't move and then reboots with the same os!!! WTH and downloading full 2.2.1 is just too big ;-;
  20. Spannaa
    KitKat Apr 9, 2016
    Spannaa , Apr 9, 2016 :
    First: Wrong forum - this is CM13 Nightlies!
    Second: You can't flash the 2.2.1 OTA over 2.1.2 - they're incremental update zips so you need to flash 2.2.0 first:
    2.1.2 > 2.2.0 > 2.2.1
