575
[OFFTOPIC] Random Nonsense Club
  1. cdnfarmer
    Photography Expert Community Expert Oct 14, 2018
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Oct 14, 2018
  3. yourdesiredusername
    Lollipop Oct 14, 2018
  4. Rick Manders
    Community Veteran Oct 14, 2018
    Rick Manders , Oct 14, 2018 :
    Welcome to the dark side. :p
    How are you liking the XS?
    And good morning RNC!
    volteon, script, Mr. BG and 5 others like this.
  5. Dresa91
    Dresa91 , Oct 14, 2018 :
    good morning:)
    script, djmfire, idkwhoiam322 and 2 others like this.
  6. Matt 80
    volteon, script, Mr. BG and 6 others like this.
  7. yourdesiredusername
    script, djmfire, Rick Manders and 4 others like this.
  8. satya.rafi
    Cupcake Oct 14, 2018
    satya.rafi , Oct 14, 2018 :
    I recently joined the club, bought an OP6, I was wondering if default camera app is the best or some other apps are better to use?
    script and JosephGLittle like this.
  9. idkwhoiam322
    Nougat Oct 14, 2018
    script, Matt 80, Dresa91 and 2 others like this.
  10. yourdesiredusername
    script, Matt 80, Dresa91 and 3 others like this.
  11. idkwhoiam322
    Nougat Oct 14, 2018
  12. satya.rafi
    just normal daylight captures. I am not a pro :)
    script and Dresa91 like this.
  13. djmfire
    KitKat Oct 14, 2018
    djmfire , Oct 14, 2018 :
    It's all filmed. Just trying to work out the whole editing thing. Got the clips in. Trimmed. Then....where the hell do I put them .....will get time to work it out tonight at work I hope
    script, idkwhoiam322, Matt 80 and 4 others like this.
  14. Mr. BG
    Community Hero 2020 Oct 14, 2018
    Mr. BG , Oct 14, 2018 :
    GMNERNC :)
    Hello Drachenjunge, same here...
    [AA-voice-over]It's been almost three years since I bought my last Oneplus device[/AA-voice-over]
    And I couldn't care less, still come here occasionally to check on the lads, how are you doing?
    Hey Rickster :)
    We should arrange a forum meet up somewhere near the German-dutch border, lol...
    No need for that, I think most of us moved on phonewise ;)
  15. script
    Moderator Moderator Oct 14, 2018
    script , Oct 14, 2018 :
    Hi,
    One important thing. When you have a scene, and then follows the next scene, you usually have two options: you do a hard cut, that means, the first scene stops, the next scene starts.
    That can work. Or not.
    Sometimes two following scenes do not look elegant when hard cut together.
    Then you can use a crossfade.
    That means, the first scene fades out, and the following scene fades in. Magically the scenes change into the next one. Often that looks nice.
    But - often it doesn't work. And that is one of the most asked questions. Why does it not fade?
    The reason is, that both scenes have to be a little longer than you think.
    Let's say, someone serves some drinks to a group of people, next scene you see people drinking.
    Scene one ends with a hand at a glass, scene two starts with a mouth at that glass.
    When you edit, you put both clips into the timeline. The timeline is simply the space where you move the clips to, one after another.
    When both clips are already trimmed, then a cross fade is not possible. Because: the crossfade needs to start somewhere. And that „somewhere“ (let's say the crossfade takes 2 seconds) starts 1 second before clip one ends, and ends 1 second after clip two started.
    Editors say, you need some seconds after the first and before the second clip of „flesh“. But, when you have trimmed both clips, there is no flesh.
    To solve this, you need to move the second clip above the first clip and move it 2 seconds (60 frames) to the left.
    That results sometimes in a not perfect solution.
    That's why clips should not be trimmed without flesh before the editing starts.
    (That is what i want to tell you)
    When you trim them, trim them two or three seconds longer at the start (before the real start) and two or three seconds longer at the end, after the scene ends.
    Then you will have enough flesh for a crossfade.
    That is an important thing to learn. :)
  16. script
    cdnfarmer, djmfire, volteon and 6 others like this.
  17. Dresa91
  18. yourdesiredusername
  19. script
    Hoi Sharin, how are you? Had a good Sunday?
  20. yourdesiredusername
    yourdesiredusername , Oct 14, 2018 :
    I'm okay, the weather is depressing though. how are you?
