3
OKAY I'M MAD NOW
  1. Erozen
    Cupcake Dec 14, 2018
    Erozen , Dec 14, 2018 :
    Thank you I'll give this a shot
  2. samprocat
    Honeycomb Dec 14, 2018
    samprocat , Dec 14, 2018 :
    Maybe you should just learn how to use phone and find out what did you screwed up
  3. AnythingWithJ
    Froyo Dec 14, 2018
    AnythingWithJ , Dec 14, 2018 :
    My friend had this problem too. Here's what he did to fix it:
    1. Boot the phone in safe mode
    2. Check if the problem your having is still there.
    3. If the problem is still there, contact OnePlus support and tell them about your problem. Of the problem is resolved by booting into safe mode, one of the apps on your device is causing the issue.
    4. Try deleting recently installed apps
    I hope this helps. (Credit: @blackmagyk)
  4. AnythingWithJ
    Froyo Dec 14, 2018
  5. B1544748182230
    Donut Dec 14, 2018
    bmwfire likes this.
  6. Max.Mar
    Jelly Bean Dec 14, 2018
    Max.Mar , Dec 14, 2018 :
    Stop watching porn on your mobile phone.. Problem solved!!
    Neddard and Zh_kilat like this.
  7. Zh_kilat
    Android Q Dec 14, 2018
    Zh_kilat , Dec 14, 2018 :
    Bull's-eye!! ....
  8. Liberatto
    Donut Dec 14, 2018
    Liberatto , Dec 14, 2018 :
    but what image are you talking about??????? I don't get it
  9. Liberatto
    Donut Dec 14, 2018
    maybe you should reconsider doing useful stuff with your life instead of spending time writing useless "tips".
  10. mercurymod
    Gingerbread Dec 14, 2018
    mercurymod , Dec 14, 2018 :
    I think that's from leaving windows or apps running from the chrome browser
  11. J_Parth_Patel_120595
    Gingerbread Dec 15, 2018
    J_Parth_Patel_120595 , Dec 15, 2018 :
    clear data of Android setup app( out of the two, only one app's data can be cleared), clear data of download manager and play store and reboot.
  12. samprocat
    Honeycomb Dec 15, 2018
    samprocat , Dec 15, 2018 :
    Sure...
    When you learn how to use Android first?
    Your issue is....
    You need special app on your phone
    How to use phone....
    No personal agenda..... just my opinion
    Trashing Forums are not very good example from you.
    Using Google would be great idea for the beginner like you.
    lordmada likes this.
  13. Bouncer71
    OnePlus 7 Pro Sample Shot Photographer Community Expert Dec 16, 2018
    Budruel likes this.
  14. tripranav
    Froyo Dec 16, 2018
    tripranav , Dec 16, 2018 :
    Bro don't worry i have created a thread with the solution to this issue, below is the details :
    "Regarding the random vibration issue on my OP6T, I think I might have found a SOLUTION (also read the same thing somewhere too and don't remember the source, so not taking credit for the solution.):
    1) Go to the file manager>internal storage.
    2) In that create a new folder (with any name you find suitable), in my case I named it New Downloads.
    3) Now go to the Downloads folder and cut/paste all the files over here to the new folder created.
    After doing this, I am not getting random vibration issue till date as there is nothing in the downloads folder and the OS does not give notification with a random vibration.
    Also after this whenever you download something just move that file to the new folder immediately. Always keep the system download folder empty.
    I have also shared this to Jeff.H from the oneplus bugs dept."
    Liberatto likes this.
  15. Liberatto
    Donut Dec 16, 2018
    Liberatto , Dec 16, 2018 :
    I'll definitely try this out and tell you if it worked in a couple of days, huge thanks for this tip!
  16. Methos777
    Froyo Dec 16, 2018
    Methos777 , Dec 16, 2018 :
    Yes.. This is something that randomly happens to me too. I thought I was missing something
  17. bpwest80
    KitKat Dec 17, 2018
    NMD2018 likes this.
  18. felipemendes
    Jelly Bean Dec 17, 2018
    felipemendes , Dec 17, 2018 :
    Never heard of it, never observed it. My downloads folder is filled with files. That's strange.
    #38
  19. Liberatto
    Donut Dec 17, 2018
    Liberatto , Dec 17, 2018 :
    sadly after doing everything you told me to, I keep getting these random vibrations
    #39
  20. tripranav
    Froyo Dec 21, 2018
    tripranav , Dec 21, 2018 :
    are you sure you do not have any files in the system downloads folder? because after doing this, since last month I have not got any random vibration.
    #40
