7
ROM Omnirom Marshmallow
  1. theshinybeast
    Marshmallow Nov 1, 2015
    theshinybeast , Nov 1, 2015 :
    don´t mention it.Credit when credit is due;):D
    #41
    Antoine Vdb likes this.
  2. ahoneybun
    Froyo Nov 2, 2015
    ahoneybun , Nov 2, 2015 :
    Alright so find7op is how OmniROM label the OnePlus One, This ROM seems pretty stable from my half hour of messing with it.
    • Call - works
    • WiFi - works
    • NFC - will not turn on
    • Bluetooth - did not try
    • Messaging - did not try
    If anyone wants me to try it out some more I will. I'll just report what I have done so far as above.
    #42
  3. skriv86
    Donut Nov 2, 2015
    skriv86 , Nov 2, 2015 :
    Im on it since yesterday. BT works. Root works.
    For nfc - just delet system/app nfc folder to exclude drain. Bat is ok. DTW works.
    Enabling SW keys works from settings (tap search box - keys), disabling HW - not.
    Have no issues with this rom, it is very stable for first release. Only one issue for me - wifi mac adress changed to strange one
    b0:aa:33:88:88:88 :(
    #43
  4. psinkar
    Cupcake Nov 2, 2015
    #44
  5. Ceasedd
    Marshmallow Nov 2, 2015
    Ceasedd , Nov 2, 2015 :
    Thanks for posting here.Will try later at my own risk of course.:)
    #45
  6. Henry80
    Ice Cream Sandwich Nov 2, 2015
    Henry80 , Nov 2, 2015 :
    I can confirm messaging (SMS, Hangouts and Whatsapp) do work: Hangouts force closed once, but then it worked.
    Bluetooth also works.
    Nokia Here Maps force closes and won't start.
    Yes, same issue about the mac address for me.
    Can't say anything on battery life now, it's too early.
    #46
    Ceasedd likes this.
  7. Lionman8595
    Gingerbread Nov 2, 2015
    Lionman8595 , Nov 2, 2015 :
    I dont understand why everytime someone posts a rom there is always some a holes trying to bust the poster nuts talking all kind bs most of the time they just like the rom! Ok , dont like it, dont use it period!
    Why doing all this shaming stuff after poster was doing some afford of digging and sharing . as for me i stoped sharing after some annoying responsses i got sharing roms . ppl dont be ungreatfull!
    Say thanx and move on.
    #47
  8. psinkar
    Cupcake Nov 2, 2015
    psinkar , Nov 2, 2015 :
    Bugs :
    Every new install app crashesh at 1st rime
    facebook app is not working
    no option for onscreen button
    root is not supporting in my case
    #48
  9. KforHorizon
    KitKat Nov 2, 2015
    KforHorizon , Nov 2, 2015 :
    Supersu v2.52 beta.zip
    Google it! And download! :)
    #49
    theshinybeast likes this.
  10. KforHorizon
    KitKat Nov 2, 2015
    Every install worked for me
    Fb and messenger crashes but that's with every MM rom out there!
    Root is supported! Flash supersu v2.52 beta
    I'll have to look for on screen buttons!
    #50
  11. Manav Bhagia
    #51
  12. skriv86
    Donut Nov 2, 2015
    Settings->search box on the top->type "keys"
    Nav bar works. HW disabling not.
    #52
  13. KforHorizon
    KitKat Nov 2, 2015
    I disabled and enabled the hardware and nav buttons respectively! Now im disabling the hardware keys light! :)
    #53
  14. Henry80
    Has anyone managed to use Nokia Here Maps with the 31 of October build of this ROM?
    #54
  15. sdrem00
    Froyo Nov 2, 2015
    sdrem00 , Nov 2, 2015 :
    I flashed this yesterday, and everything seems to be running smoothly. All my apps and data restored with Google restore, installed Google camera because of more options, installed layers for theme support. Battery dropped from 100% to 90 overnight. I see there is a doze settings tweaker out there, might have to try it.
    #55
  16. Manav Bhagia
    Ice Cream Sandwich Nov 3, 2015
    #56
    agbazinga and mykel_shoemaker like this.
  17. semper80
    semper80 , Nov 3, 2015 :
    Go to EsFile Explorer (with root acces)/device/data/app/com.facebook.katana-1/lib/arm and delete libsslx or libliger. Do not restart. It will work. After each restart must repeat this step.
    #57
  18. VikramD007
    Cupcake Nov 3, 2015
    VikramD007 , Nov 3, 2015 :
    Few bugs, plz revert if can be fixed, 1 button option is not available, 2 incall and outcall ui not working, 3 titanium back is not working, rest the ROM is really smooth and love to use if these can b fixed
    #58
  19. mykel_shoemaker
    Honeycomb Nov 4, 2015
    mykel_shoemaker , Nov 4, 2015 :
    Omnirom was one of the best one I used on my SGS3. I'm happy to see an early release for 6.0.
    Tried it with multirom. Bootloops.
    Tried without multirom and working good. Had one unexpected reboot. Other than that, didn't notice much issues yet. Will do more testing over weekend.
    #59
  20. elanglois
    Lollipop Nov 4, 2015
    elanglois , Nov 4, 2015 :
    Here my 2 cents.
    Telling people about ROMs is fine. I've done it, but just give a link to XDA. Like it or not, the userbase there is more advanced and better able to answer questions. Don't give direct download links! If someone can't read and research on their own, they don't need to be flashing.
    Now ... Android 6 is different. At best, its a beta off of AOSP. And might be CM 13 which crashes horribly right now. Due to the beta nature, it does NOT belong here. Only people capable of recovering from a brick and capable of submitting a catlog should deal with M on OPO right now. Those people already know where XDA is.
    By posting here you open the floodgates to people that want the latest and will brick their phone for the chance to do so.
    I strongly recommend this thread be removed
    #60
