3
One plus 2 battery life ...
Will any further developments on software will increase battery life?
  1. Yes
    159 vote(s)
    82.0%
  2. No
    35 vote(s)
    18.0%
  1. dynasty96
    Gingerbread Oct 3, 2015
    dynasty96 , Oct 3, 2015 :
    I average 5 hr SOT, using spotify, kik, browsing, YouTube, Bluetooth... People complain so much but don't want to optimize their phone. Do your research...
  2. willy156
    Honeycomb Oct 3, 2015
    willy156 , Oct 3, 2015 :
    how the heck do you guys get 6+ hours of SoT? I'm just sitting here losing 1% every ~10 minutes while the phone is off.
  3. dynasty96
    You gotta root your phone first off. Theres many guides, and from there you can flash AK kernel and xposed and use amplify and greenify (assuming you know what these are). Over time, there will be battery saving tips as custom roms continue to grow and marshmallow gets released
  4. jmudrick
    jmudrick , Oct 3, 2015 :
    Not necessarily do you need root. It really has a lot to do with what apps are causing battery drain. App Permissions is the first line of defense which is part of stock settings.
  5. dynasty96
    Using the xposed module appops (which requires root) gives you more in depth options to disable permissions for certain apps. And it is good to have root as well because you have an array of options for optimizing your phone to your liking and needs
    Spliffman likes this.
  6. bellamrams
    bellamrams , Oct 3, 2015 :
    yes bro...u r right...
  7. jmudrick
    Correct. Simply suggesting for someone who may not want to root that App Permissions is there and should be tried.
  8. dynasty96
    True, just letting people know the other options they have, instead of bashing a pretty good phone
  9. alex inthi
    Ice Cream Sandwich Oct 3, 2015
    alex inthi , Oct 3, 2015 :
    For me OnePlus One gives more SOT than OnePlus 2
  10. ram1987
    ram1987 , Oct 3, 2015 :
    There should be definitely battery software update to improve efficiency..
    MJiggles likes this.
  11. kanagadeepan
    KitKat Oct 3, 2015
    FalconFX likes this.
  12. swk1999
    Eclair Oct 3, 2015
    swk1999 , Oct 3, 2015 :
    OnePlus 2 Android OS use the most battery? Android system also uses a hell lot of battery. What the heck!!!
    I tried to turn if gesture. I tried turning of sync. I've tried turning off location. But it is still not passing one day....
    Who has the gut to try out nightlies CM12 for us? Report the battery life, OST and charging time to us then.
  13. deevil
    deevil , Oct 3, 2015 :
    iphone 6 with 8 hrs SOT? where do you get this information...?
    this would be a record......
  14. deevil
    try uninstalling/reinstalling google services and clearing its cache.
    some report, this is happening, because of a recent update, that has some issues for some reason.
    I did it too, but am still investigating.
    wake log checker seems to suggest though, that it worked.
  15. chrsfrwll
    chrsfrwll , Oct 3, 2015 :
    Since you're the one complaining, why don't you?
  16. swk1999
    Eclair Oct 3, 2015
    I'll definately do it. But now is not the time because I'm having exam.
  17. alex inthi
    I experienced myself :)
  18. jmudrick
    Honeycomb Oct 5, 2015
    jmudrick , Oct 5, 2015 :
    For me as well. That doesn't mean that battery sucks on the OnePlus 2 just because it falls short of best in class. Fact is I don't know another current model that does as .OP2 is better than Galaxy S6, better than Moto-X, better LG-4, better than M9.
    #38
  19. RistoEe
    RistoEe , Oct 5, 2015 :
    My SOT is usually around 6h and I'm happy with that. I don't see why people are complaining about battery life if they get reasonable SOTs. And if not, 1st thing to do is to check what's draining the battery (imho best way for this is root + better battery stats).
    #39
    atiq.qasim.12 likes this.
  20. logmms
    Gingerbread Oct 5, 2015
    #40
