one plus 3 battery drain so fast
  1. Jaiarya_25
    Cupcake Apr 17, 2017
  2. TweakIt
    Honeycomb Apr 17, 2017
  3. Woodysk
  4. coolabhi
    Cupcake Apr 18, 2017
    coolabhi , Apr 18, 2017 :
    I usually follow below points (picked it up from experts in this forum)
    1. Close unwanted open apps (i do this exercise 3-4 times a day...really helps)
    2. You can turn off only those gestures which you really use. I use only screenshots rest of all is turned off (Personal experience it helps)
    3. Turn of the location, bluetooth, and wifi when not required. (Maximum saving from this 3).
    I follow above rules and get complete 1 day battery life.
    one cent from my side. Hope this helps.
  5. sunil.phys
    Cupcake May 19, 2017
  6. pkair
    Honeycomb May 20, 2017
    pkair , May 20, 2017 :
    No issues here. Battery works like a charm but I have OP3T I am on Beta 7 wifi/bt on all day. all locations access for the apps that dont need it is disabled. wlan filter on. auto brightness on. auto night mode off.
  7. Kirakichi
    Jelly Bean May 20, 2017
    Kirakichi , May 20, 2017 :
    That statistic is from 5% drain from 100% to 95%.
    On some devices, some people say from 100% to 90% their drain is double, and then. from 90% it settles down.
    Yours could be similar, don't take it too seriously and use it for 1h.
    If you unplugged it and used it straight to 95% from 100%, it means you used your phone for 10min and during that time your device did drain quite normal.
    1) I suspect you run all settings ON + 4G Dual Sim.
    since unplug you constantly used it and thus, that info says you the Screen On Time you got left BECAUSE the phone never went to idle, so that can be counted as your total screen on time being left.
    It is normal if you run with all features on, so don't be too worried.
    sreenathkaredath likes this.
  8. Binar91
    Cupcake May 20, 2017
