OxygenOS One plus 3 doesn't start
  1. L0r3n2
    Donut Apr 6, 2017
    L0r3n2 , Apr 6, 2017 :
    Good morning,
    I have a little big issue :D
    This night I charged my OP3 and today morning I pressed the powerbutton and nothing happened.
    After that I press the power button and volume down, for the recovery, also nothing happened. So I put it again on the charge cable. but there happened also nothing.
    I haven't any special roots or cracks on my phone. I use it totally normal.
    Do you have any ideas?
    best regards L0r3n2
  2. Sun90
    Starting Point Expert Community Expert Apr 6, 2017
    Sun90 , Apr 6, 2017 :
    Did you check whether the charger is working properly or not for now.
  3. L0r3n2
    Donut Apr 6, 2017
    Yes I also checked an other USB-C cable :(
  4. Sun90
    I meant , if the charger is working fine while charging other phone.
    If not then the charger is the culprit.
    If it does charge other phones, then there seems some serious hardware failure on the phone, which needs a service centre aide.
  5. marcocartella
    Gingerbread Apr 6, 2017
  6. L0r3n2
    Donut Apr 6, 2017
    Yes i charged also an other oneplus3 with this charger, there was all good. So i have to contact oneplus?
  7. L0r3n2
    Donut Apr 6, 2017
    there also nothing happens :(
  8. Sun90
    Then it would be better to contact op support and seek help.
  9. mharis
    Ice Cream Sandwich Apr 6, 2017
    Best Answer
    mharis , Apr 6, 2017 :
    You mean the phone is just - dead?
    Let me re-iterate, you have tried:
    1. Long pressing power button
    2. Long pressing power + volume down
    3. Long pressing power + vol up
    4. Connecting a charger (Does the LED light up when you connect charger? Or does the screen?
    5. Connecting via data cable to a PC
    If none above works for you, this may have no solution but to contact customer support.
  10. L0r3n2
    Donut Apr 6, 2017
    Yes I test it all, and no LED/screen when i connect to charger or pc, and no opportunity to get on the data when i connect to pc.
    Okey thank you, but they make probably a factory reset ?
    PS: The phone is quite warm???
  11. mharis
    If the phone is not responding to anything as you mentioned, then you're in for either a replacement or a repair.
  12. G_rajath_t.s_Xobp
  13. L0r3n2
    Donut Apr 6, 2017
    okey, thank you
  14. L0r3n2
    Donut Apr 6, 2017
    but, if it is n battery issue, i think the device has to start, when I put it on charge?
  15. L0r3n2
    Donut Apr 6, 2017
    After a half day, it still not starts. But now i get in recovery mode, there I reboot, now it's all good! :)
    But thanks for the support
  16. L0r3n2
    Donut Apr 6, 2017
  17. rohit.bhosale
    Cupcake Apr 6, 2017
    rohit.bhosale , Apr 6, 2017 :
    This happened to me today. Phone battery was at around 30% when I last checked. And then it just wouldn't start at all. I connected the charger and left it for sometime. pressed the power button for long time and the phone got back up again.
  18. tOot.toOt
    Froyo Apr 6, 2017
    tOot.toOt , Apr 6, 2017 :
    try to connect ur device to the PC and check ur device is detected or not in Device manager.
  19. F_Manab_Bhattacharjee_xg
    Cupcake Apr 6, 2017
  20. tushar.gaikwad
