one plus 3 headphone mic does not work during calls
  1. Ahmedzayed90_90
    Cupcake Oct 12, 2019
    Ahmedzayed90_90 , Oct 12, 2019 :
    hi every one
    i am one plus 3 user and i have the following problem
    when fully plugging the 3.5 mm headphone male cable into its socket the mic notification become like the attached photo and the mic switches off
    the only way to use mic during calls is plugging the cable half the distance into the socket and that makes it always between on and off with any touch or movement
    any help please
  2. Paschfire
    KitKat Oct 12, 2019
    Praty_28 likes this.
  3. Ahmedzayed90_90
    Cupcake Oct 23, 2019
    Ahmedzayed90_90 , Oct 23, 2019 :
    thank alot . indeed the 3.5 mm was full of dust , i manged to clean it and it works perfectly and i will keep my OnePlus 3
