One plus 3 power nd volume button availability via OnePlus 9R
  1. Sagarchawla88
    Cupcake Aug 11, 2021
    Sagarchawla88 , via OnePlus 9R , Aug 11, 2021 :
    Hi
    I wanted to repair my one plus 3 power nd volume buttons but service center in netaji subhash palace new delhi doesn't have buttons availablity, after diagnosis they said. Its not available now plz help me out from wher to get the both buttons , technician said button rubber are damage that's y its not pressing.
    Looking forward for your support
  2. G_Mohit_Dalal_VeLN , via OnePlus Nord 2 Blue Haze , Sep 22, 2021 :
    Bro I had the same problem with my 3t and they did not had the part.so I had to change my phone to Nord 2.
    Bro their is a fix in local shops.they will paste it and it will work fine.It won't be rock solid but can be referred to as a jugad.
    Try not to use that button too often.Only for accidental swtich off.And you will be good to go.
    Don't ever go to gaffar they will steal your original parts and replace your display.
    Go to a repair shop that is willing to repair your phone in front of your eyes.There are some people who will repair in front of you and later take the device to another shop and then steal your parts so be aware.
    Some shops also have the rubber button you can ask them.
