one plus 3 screen de gumming due to which it is popping out from top corner
  1. Anupsakharee
    Cupcake Feb 6, 2019
    Anupsakharee , Feb 6, 2019 :
    Hello Guys,
    one plus 3 screen de gumming due to which it is popping out from top corner. service centre advice me to change the entire display. I don't think that is required because it's just the gum which needs to be placed.
    please suggest
  2. Moin2200
    KitKat Feb 6, 2019
    Moin2200 , Feb 6, 2019 :
    Get it fixed at a security center if you don't have experience in this field as it is much more safer.
    Or chew some gum and stick it in.
    Anup.sakhare likes this.
  3. Arun Sharma
    Gingerbread Feb 6, 2019
    Arun Sharma , Feb 6, 2019 :
    Tons of OnePlus 3 has this issue..
    I went through the same thing
    got it fixed for 300INR about 3 months ago
    at Nehru place New Delhi IND.
    please don't try to fix it on your on using any kind of glue
    Ask the repair guy for ga lue that becomes rubber kind of thing when it dries.
  4. Anupsakharee
    Cupcake Feb 6, 2019
    Thanks Arun :)
  5. Ciprianbitica
    Cupcake Feb 6, 2019
    Ciprianbitica , Feb 6, 2019 :
    I had the same problem a few months ago. Send it to OP service and they replace the whole screen.
    Try to open a ticket on OP service and talk to them.
  6. G_Siddhant_Chipre_iPMy
    Cupcake Feb 6, 2019
  7. G_dhaval_shinde_ZupO
    Froyo Feb 9, 2019
  8. Fathaah Ansar
    Gingerbread Feb 14, 2019
    Fathaah Ansar , Feb 14, 2019 :
    For the time being you can invest in a bumper case, which covers the device all around, it must hold the screen on. At least you can use the device that way while it's in this state
  9. F_Woraphong_Prathum_OSbN
    Cupcake Feb 14, 2019
    F_Woraphong_Prathum_OSbN , Feb 14, 2019 :
    I met the same problem. The cause was swollen battery that popped the screen out. I had to replace battery by myself due to no service center in my country.
  10. gautamgzb2
    Donut Feb 14, 2019
  11. G_Micale_HSWg
    Eclair Feb 15, 2019
    G_Micale_HSWg , Feb 15, 2019 :
    just to share my similar experience.
    My OP3 screen was pop out, I just replace the battery and rear housing (cuz I prefer black housing). just cheap parts from ********** and my problem was fixed, I dont even use any glue. How to tear OP3 apart, just find them from youtube.
  12. Narender
    Eclair Feb 15, 2019
    Narender , Feb 15, 2019 :
    I had the same about an year ago due to falling but i fixed it in 5 rs by applying fewiquick and its all fine and therse no problem
