One plus 3t After update 5.0.3 oxygen os lot of problems
  1. W1517925203521 Cupcake Aug 11, 2019
    W1517925203521, Aug 11, 2019 :
    I have Using 1 and Half years using one plus 3t I have so many problem and mobile his hanging after oxygen os(5.0.3) update, Last december month 2018. I have already tell him in OnePlus community , please solve my problem and back key his not working to normal..
  2. Paschfire KitKat Aug 11, 2019
    Paschfire, Aug 11, 2019 :
    First I suggest you try installing the latest OOS version released, OOS 9.0.5 Android 9 Pie, followed by a factory reset.
    As the build you're running is very outdated.
    If the back-key continues to not function after performing a factory reset, then it's likely to be some sort of HW failure or damage. In this case take or send your device into a OnePlus service center for inspection of possible repairs.
  3. Paschfire KitKat Aug 11, 2019
    You also received an answer last time you posted, I suggest you actually READ the response you were given.
  4. S1509801375025 Gingerbread Aug 11, 2019
  5. Paschfire KitKat Aug 11, 2019
    I've had it for a month or so.
    Are you part of the community app beta tester program? You sign-up through the PlayStore.
    If you have the community app version 2.6.0.19... Just look for the dark mode toggle within the profile tab.
  6. S1509801375025 Gingerbread Aug 11, 2019
    S1509801375025, Aug 11, 2019 :
    Oh so, this one is for beta users right?
  7. Paschfire KitKat Aug 11, 2019
    I'm guessing so, but not completely sure.
    What version are you running?
    You could probably grab a copy of the APK from apkmirror.com
  8. S1509801375025 Gingerbread Aug 11, 2019
    I am not on the beta program. So maybe this isn't available for the official community app. Also, it says beta program is full for this app. So, the apk won't work right?
  9. Paschfire KitKat Aug 11, 2019
    Just means you cannot join the beta tester program at this time. So no, you cannot install it via PlayStore currently.
    Though... You can still sideload it manually by downloading the APK from here.
    https://www.apkmirror.com/apk/onepl...community-2-6-0-190725182209-5e9af04-release/
    Praty_28 and S1509801375025 like this.
  10. S1509801375025 Gingerbread Aug 11, 2019
  11. Paschfire KitKat Aug 11, 2019
    S1509801375025 likes this.
  12. Paschfire KitKat Aug 11, 2019
    Let me know how it goes for you, though I don't foresee any issues.
  13. S1509801375025 Gingerbread Aug 12, 2019
    S1509801375025, Aug 12, 2019 :
    It has been an untroubled experience till now. But I must say you people had so many more features than we used to have!
  14. ghostofcain Marshmallow Aug 12, 2019
    ghostofcain, Aug 12, 2019 :
    That's kinda the idea of a beta , to test out new, possibly unstable, features.
    Paschfire likes this.
  15. S1509801375025 Gingerbread Aug 12, 2019
    Yeah.. I am aware of that.
  16. S1509801375025 Gingerbread Aug 14, 2019
    S1509801375025, Aug 14, 2019 :
    Now this dark theme feature is made available even for non-beta programmers.
  17. W1517925203521 Cupcake Aug 16, 2019
    W1517925203521, Aug 16, 2019 :
    ok but why mobile his slower than before update tell me and one day in this problem I have seeing this , what are the reason in this problem happened.. back key his many time his not working and after android version 9 back key his working..and inthis time back key not working..before update pubg game his clear and smoothness to playing but after update pubg game his equal to 2 & 3 GB ram mobile...pls solve my problem and Iam waiting Next one plus serious, I guess oneplus 8 right...
