One Plus 3T Camera focus issue
  1. G_Kaustubh_Bagade_WDix Cupcake Apr 12, 2018
    G_Kaustubh_Bagade_WDix, Apr 12, 2018 :
    IAM facing camera issue on my one plus 3T .
    The rare camera dose not focus on the object selected and the entire background turns blur.
    Kindly provide me the solution or fix the bug
  2. 9824110714 Cupcake Apr 12, 2018
  3. AtomicEntity Gingerbread Apr 12, 2018
    Sun90 likes this.
  4. octavianf Cupcake Apr 12, 2018
    octavianf, Apr 12, 2018 :
    Hi,
    I had same issue and phone was in service and camera part replaced.
    This is how it was fixed, after hard reset of phone.
    Best regards,
    Florin
    sachinsyam likes this.
  5. sreeragvn Cupcake Apr 12, 2018
  6. V1541473548555 Cupcake Nov 6, 2018
    V1541473548555, Nov 6, 2018 :
    I can't focus on texts and also normal photography with rear camera. If i have to translate a text using Google translate i cant use my camera.. Even with other camera FV5 app. I can't use for google translate because this app uses default camera.
  7. Y1541323635605 Cupcake Nov 6, 2018
    Y1541323635605, Nov 6, 2018 :
    face gesture should still improve even it got unlocked by my brothers face so please one plus team do work on it and send some update fingerprint is good no any problem face gesrure
  8. Paschfire Jelly Bean Nov 6, 2018
    Paschfire, Nov 6, 2018 :
    Use the forums search to find answers.
    See here for the solution,
    https://forums.oneplus.com/threads/camera-issue.929489/
  9. sachinsyam Cupcake Nov 8, 2018
  10. V1541473548555 Cupcake Nov 9, 2018
  11. Paschfire Jelly Bean Nov 9, 2018
    Paschfire, Nov 9, 2018 :
    Are you blind? Ad the answer is within the link you quoted.
  12. Narayan13 Eclair Nov 10, 2018
    Narayan13, Nov 10, 2018 :
    i had experienced this twice. Both times Oneplus replaced rear camera for free of cost. This is a known issue in OP3.
