5
Other One plus 3T problems
  1. ramakrishh059
    Cupcake Nov 5, 2019
    ramakrishh059 , Nov 5, 2019 :
    After the recent update there has been lot of issues with the phone (OP3T). First and foremost it was aa huge thing to get my mobile on after the update. Had to reset my phone after update (lost most of my data) and had to reset again after the following issues mentioned below (but to no avail):
    1. The phone is laggy.
    2. Apps and screen stops responding
    3. Incoming call screen shows up after 10-15 seconds.
    4. Most of social media app screens have a laggy and jerky screen response for swipe.
    5. Battery drains faster.
    6. Game apps are laggy.
    7. Mobile response is slow (doesn't feel like a 6GB RAM phone).
    8. Have to tap multiple times sometimes to select something.
    I think they want us to buy their new phones and hence have given an update whih doesn't suit the hardware. I have suggested many of my friends to go for OP in the past and have personally convinced them into buying. From now on i am going to suggest them to stay away from OP phones.
  2. pablofg1978
    Nougat Head Moderator Nov 5, 2019
    pablofg1978 , Nov 5, 2019 :
    I have a 3t and I don't face any of those problems, even the battery holds well considering that has 3 years old.
    Contact support or visit a service center, maybe you have another problem
    P1556547352498 and Bouncer71 like this.
  3. Chaser Lee
    Froyo Nov 5, 2019
    Chaser Lee , Nov 5, 2019 :
    If you install a custom ROM such as Havoc-OS Pie for the 3T, all those problems will go away. I did, and have never been happier with my 3T. Much better camera, battery life SOT, and the launcher can't be beat. Something to think about...
  4. M1573041205198
    Cupcake Nov 6, 2019
    M1573041205198 , Nov 6, 2019 :
    One Plus 3T es el mejor teléfono celular que he tenido, traté de flashear su teléfono o analizar las aplicaciones que instaló directamente, solo instale las aplicaciones que están disponibles en Playstore. También tengo el problema de que la pantalla de llamadas entrantes aparece después de 10-15 segundos y es debido a uno de los juegos que siempre se ejecuta en segundo plano. Y si instaló un sistema operativo personalizado, entonces también es la razón por la cual el teléfono móvil es lento.
  5. Chaser Lee
    Froyo Nov 6, 2019
    Chaser Lee , Nov 6, 2019 :
    What custom OS did you install to give you that experience and opinion?
  6. M1573041205198
    Cupcake Nov 7, 2019
    M1573041205198 , Nov 7, 2019 :
    Oxygen OS 7.1.1 Open
  7. Chaser Lee
    Froyo Nov 7, 2019
    Chaser Lee , Nov 7, 2019 :
    I see. If I may suggest something? Do a nandroid backup of your current custom rom install, then install Havoc-os 2.9 (Android 9). Spend a couple days with it, and see if you realize any improvement. You won't know, if you don't try. :)
    If it's not for you, then restore the backup you made, and you are back to where you are now, except you have gained some knowledge and experience with Havoc-OS.
  8. K1573374973393
    Cupcake Nov 10, 2019
  9. Chaser Lee
    Froyo Nov 10, 2019
    Chaser Lee , Nov 10, 2019 :
    After installing Havoc-OS 2.9 you can't open your camera, is that what you mean? If so, did you follow the instructions for flashing that version of the ROM? I suspect that you didn't flash the OOS 9.0.5 firmware zip first, before flashing the Havoc rom. Could I be right about that? If so, that's why you can't open the camera. Once you get all that done, I'll point you to a camera that you can run on Havoc that is 10 times better than the OnePlus camera. Let me know how it goes.
  10. H1568044785600
    Cupcake Nov 13, 2019
  11. Chaser Lee
    Froyo Nov 13, 2019
    Chaser Lee , Nov 13, 2019 :
    There are custom roms for android 10 for our 1+3T, but nothing 'stock' from OnePlus.
  12. H1568044785600
    H1568044785600 , Nov 13, 2019 :
    is there any upcoming one
  13. Chaser Lee
    Froyo Nov 13, 2019
    Nope. The 3T has reached EOL (end of life) as far as OnePlus is concerned. There is speculation on the possibility of even getting one more security update for Android 9. As far as Android 10 goes, if you want it, you'll have to install a custom rom.
  14. H1568044785600
    how do i install a custom rom
  15. Chaser Lee
    Froyo Nov 13, 2019
  16. H1568044785600
  17. Chaser Lee
    Froyo Nov 13, 2019
    H1568044785600 likes this.
  18. E1512836243831
  19. H1568044785600
  20. mhdnizar
    Eclair Nov 14, 2019
