One plus 40y Optical Output Volume Control via OnePlus 7T
  1. D1570207907098
    Cupcake Jun 3, 2021
    D1570207907098 , via OnePlus 7T , Jun 3, 2021 :
    Hai I have bought new one plus 40y .. Everything is good but when I connected my home theater with optical cable I can't control sound ..we have to manually change sound ..
  2. Yash Pratap Singh.
    Lollipop Jun 3, 2021
    Yash Pratap Singh. , Jun 3, 2021 :
    The sound output level from the TV to the optical cable home theatre is fixed and cannot be controlled from the TV's remote.
    You will need to use your HT's remote to control sound output via HT (home theatre)
    Tobikage, Tokolozi and Venky61 like this.
  3. Venky61
    OnePlus TV Expert Community Expert Jun 3, 2021
    Venky61 , Jun 3, 2021 :
    As rightly pointed by @Yash Pratap Singh. you cannot control the volume of sound output through Optical Cable with TV remote. If your sound system supports BT mode or HDMI ARC, you may switch to that mode to be able to control the volume with TV remote.
    Tobikage and Yash Pratap Singh. like this.
  4. Yash Pratap Singh.
    Tokolozi likes this.
  5. Tokolozi
    Most Original Avatar Jun 3, 2021
  6. Yash Pratap Singh.
    Only delay? Distortion, stuttering....delay becomes unnoticable amidst the other BT issues 😂
  7. D1570207907098
    Cupcake Jun 4, 2021
    D1570207907098 , via OnePlus 7T , Jun 4, 2021 :
    Tq buddy
    Venky61 likes this.
  8. D1570207907098
    Cupcake Jun 4, 2021
    Tq.man..i will check and sort it out.
    Yash Pratap Singh. likes this.
  9. Yash Pratap Singh.
    Lollipop Jun 4, 2021
    Yash Pratap Singh. , Jun 4, 2021 :
    As Venky said, you may try HDMI ARC since Bluetooth has a little delay
  10. Venky61
    OnePlus TV Expert Community Expert Jun 4, 2021
    Venky61 , Jun 4, 2021 :
    Let me tell you a funny thing. BT works better on Y series than Q and U :p
    No distortion till now and lag only in couple of instances which seemed to auto-set in some time, as per my experience till now.
  11. Yash Pratap Singh.
    Damn....:eek::eek::eek:
    Seems unfair 😂
