4
One Plus 5 battery drain
  1. shivam.saha06
    Donut Nov 19, 2018
  2. hangover
    Cupcake Nov 19, 2018
    Alouetteridge and shivam.saha06 like this.
  3. Y1542610562670
    shivam.saha06 likes this.
  4. anupritaisno1
    KitKat Nov 19, 2018
    anupritaisno1 , Nov 19, 2018 :
    If android system is on the top of your battery charts then your phone is optimising
    Connect a charger and the optimisation will happen faster
    Connect your phone to a charger at night, there is no reason not to
    Explanation: https://forums.oneplus.com/threads/closed-battery-performance.911024/#post-19181266
    Open that link in a browser and not the community app
  5. Y1542610562670
    Y1542610562670 , Nov 19, 2018 :
    How long will this optimization algorithm run? If it is running continuesly in background then it is not good idea with this tremendous power cost.
  6. anupritaisno1
    KitKat Nov 19, 2018
    That depends on how many apps you have installed
    You can force the optimisation by running this command in an adb shell. Root is not needed
    cmd package bg-dexopt-job
  7. Mr. Vandelay
    Jelly Bean Nov 19, 2018
    Mr. Vandelay , Nov 19, 2018 :
    Wipe the cache partition (It won't erase any personal data (Music,pics, etc)).
    1. Turn the phone off.
    2. Hold Power and Volume Down
    3. English
    4. Select Wipe data & cache
    5. then select Wipe cache
    6. Yes
    7. Reboot
    buntycubal likes this.
  8. Y1542610562670
    thanks
  9. hangover
    hangover , Nov 19, 2018 :
    did not help at all. still huge drain.
  10. Mr. Vandelay
  11. Ishan_007
    Eclair Nov 19, 2018
  12. anupritaisno1
    KitKat Nov 19, 2018
  13. anupritaisno1
    KitKat Nov 19, 2018
    Go and actually read the code to understand what the cache partition really stores
    You want to know what it really stores? It stores nothing at all
  14. cedric88350
    Froyo Nov 19, 2018
    cedric88350 , Nov 19, 2018 :
    Si il n'y a pas à d amélioration il faut réinstaller la rom que vous pouvez trouver sur le site web oneplus.com
    NateDev likes this.
  15. Ishan_007
    Eclair Nov 19, 2018
    Ishan_007 , Nov 19, 2018 :
    Recently I reset my one plus 5t.So I think there are nothing in the catch memory....
  16. anupritaisno1
    KitKat Nov 19, 2018
    There is no need to reinstall the ROM because this phone has dm-verity
    Il ne faut pas réinstaller la ROM parce que c'est portable a le dm-verity
  17. anupritaisno1
    KitKat Nov 19, 2018
    Many people do not even know what is in cache and wipe it without giving it a second thought
    Wiping the cache is NEVER a solution. It is just a myth
  18. cedric88350
    Froyo Nov 19, 2018
  19. cedric88350
    Froyo Nov 19, 2018
  20. anupritaisno1
    KitKat Nov 19, 2018
    No, if you're saying that is needed then you're wrong
    If you have found a bug in dm-verity Google should reach you
    Have you? Go report it to them
    Stop being an idiot. Do not reflash ROMs on a whim because it does nothing
