one plus 5 garmin connection
  1. innermonkeyboy
    Cupcake May 27, 2020
    innermonkeyboy , May 27, 2020 :
    Hi, all i had to send my phone off for repair i got it back and it keep disconnecting from my Garmin 5x watch and reconnecting. Before i sent it off it worked fine, I've tried everything to sort it out resetting the phone and settings and the watch and settings cold boots also on both. Does anyone know what else i can do to resolve it? as my fitness targets aren't getting updated with my vitality all the time due to the loss of connection every so often.
    any help would be appreciated.
    Many Thanks
  2. Liehjan
    Lollipop May 27, 2020
    Liehjan , May 27, 2020 :
    Have you updated to android10, if not do that first and see if it helps with the issue.
  3. innermonkeyboy
    on android 9, but its not giving me the option to go to android 10.
  4. Liehjan
    It's rolling out right now, wait for the ota or use oxygen updater app...
  5. innermonkeyboy
    Roger that, hopefully it will sort it out. Only got the one plus 5 still as i had a huawei p30pro on contract but didn't like it so went back to the OP5. Getting OP8 September.
  6. nmonteirinho
    Cupcake Aug 6, 2020
  7. Herculess
    Cupcake Aug 13, 2020
    Herculess , via OnePlus 8 Pro , Aug 13, 2020 :
    Hello, I have problem with the bluetooth connection from an update in android about mars this year. I have Friends that have the same problem bit using onther phones witch also rund android ang get the same update problem.
  8. Teekar.2023
    Gingerbread Sep 1, 2020
    Teekar.2023 , via OnePlus 5T , Sep 1, 2020 :
    It's not rolling out. It was rolled back due to bugs.
