2
one plus 5- overheating and battery drain issues
  1. Shaik009
    Cupcake May 1, 2018
    Shaik009 , May 1, 2018 :
    i updated my one plus 5 to Android 8.0 oreo.. after updating my device i started to experience battery drain.. and quiet recently i received the 8.1 oreo upadate.. and after updating my device i started experiencing increase in my device temperature.. is this a kind of bug or something.. need immediate feedback!!..has anyone got the same issues??
  2. the_o2
    User of the Year 2018 May 1, 2018
    the_o2 , May 1, 2018 :
    Restart your phone once and let settle down the android system, it takes time to settle down after every major updates, don't get panic be patience phone will be fine in one or two days.
  3. Shaik009
    Cupcake May 1, 2018
    ya i totally agree with that.. but i've restarted my phn after that several times..it's been like 3 to 4 days since i've got the update.. And wht about the battery draining issue.. it's been with me like since the oreo update.. anyways thank's man for your valuable reply .. really do appreciate it..
  4. b1r2b3
    Cupcake May 1, 2018
    b1r2b3 , May 1, 2018 :
    After oreo update battery draining. Android system is using about 70%
  5. Gav_W86
    Starting Point Expert May 1, 2018
    Gav_W86 , May 1, 2018 :
    boot into recovery mode and clear the cache
    Shaik009 likes this.
  6. dardan.shabani
    Cupcake May 1, 2018
  7. the_o2
    User of the Year 2018 May 2, 2018
    the_o2 , May 2, 2018 :
    just do these 2 things..
    First: Go to setting->storage and memory (scroll down)-> cached data(click and clear the cache).
    and then
    Second: Wipe the cache partition by following step.
    1. Turn the phone off(unplugg the charger if charging).
    2. Hold Power and Volume Down
    3. English (or pick any language that you want)
    4. Wipe data & cache
    5. Wipe cache
    6. Yes
    7. Reboot.
  8. G_Sharath.S._Nair_oMhE
    Eclair May 2, 2018
  9. X1513001495748
    Gingerbread May 2, 2018
    X1513001495748 , May 2, 2018 :
    and then
    5. Wipe cache
    6. Yes
    7. Reboot.
    After doing this > Charge your phone fully and use it until it get zero % . Do it for at least 3 time full charge and discharge.
  10. oneplus5t user
    Cupcake May 2, 2018
    oneplus5t user , May 2, 2018 :
    when will the battery issue bug get fixed ?
    new Oreo update is spoiling the performance of this Wonderful phone !
