2
One Plus 6 battery drain
  1. Daxoneplus6
    Eclair Jun 24, 2018
    Daxoneplus6 , Jun 24, 2018 :
    Hello,
    The battery drains super quick after the latest update.
    Just few minutes after full charge.
    M1527187066228 and Kvsm123 like this.
  2. Rish2111
    Cupcake Jun 30, 2018
    Rish2111 , Jun 30, 2018 :
    thought i was the only one facing it!
    we're in the same ship. hope they fix this soon. :/
  3. Sagar Asthana
    Eclair Jul 21, 2018
    Sagar Asthana , Jul 21, 2018 :
    my battery drains quick from 100 till 95% and then drains slowly after that. One month back when i bought the phone the battery used to drain very slowly even from 100%, but now this is happening. I'm not complaining about it but earlier i used to get 7 hours plus of screen on time and now i am getting 6 to 6.5 hours. This is still very good battery life but yeah it somewhat bugs me to see the quick initial drop of 5% when fully charged.
  4. U1527789421816
    Cupcake Jul 28, 2018
  5. Q1530805016224
    Cupcake Aug 9, 2018
  6. U1527789421816
    Cupcake Aug 9, 2018
  7. Q1530805016224
    Cupcake Aug 9, 2018
  8. maulikmax
    Cupcake Oct 31, 2018
    maulikmax , Oct 31, 2018 :
    I am also having battery drain issue after Android pie update I am able to get roughly 4 hours of screen on time... please do something about this.
  9. Gav_W86
    Moderator Moderator Oct 31, 2018
    Gav_W86 , Oct 31, 2018 :
    ok, you have been actively using the phone for 20mins out of the first 43mins since charge. The figures there are estimates based on learnt use, and that resets after an update. A) let things settle down for a few use/charges first, and B) look at the charts after a full (100% to <10%) single charge use for fuller info.
  10. Gav_W86
    In 31% you have had 11hrs on and 1.5hrs screen on time. Not great, but not awful. post the figures after a full (100% to <10%) single charge use.
  11. Gav_W86
    it all depends on what apps/services are using. what do the battery use screens in settings say? checkthe figures after a full (100% to <10%) single charge use.
  12. sriramsss87
    Donut Dec 2, 2018
    sriramsss87 , Dec 2, 2018 :
    me too facing the same issue, after the latest update my battery last only 8hrs compared to the 16 hrs it gave previous
  13. sriramsss87
    Donut Dec 2, 2018
    I fairly use the same apps the I used before the update and got 16hrs, now after the update it's lasts me less than 8hrs, OnePlus pls look into it, it affects my work-life
  14. patriot_rahul
    Cupcake Jan 29, 2019
    patriot_rahul , Jan 29, 2019 :
    Battery drains by upto 20% overnight,. even when data, location wifi everything is off. Earlier it used to lose max 5 % overnight. The latest update has messed things up.
    Screen on time of 4hrs 30mins is disappointing, earlier i used to get above 6 and a half hour .
  15. C1568006847856
    Cupcake Sep 9, 2019
    C1568006847856 , Sep 9, 2019 :
    Yes sir from 4 to 5 days my mobile battery is draining soo quickly. In doesn't use my mobile then to mobile mobile battery is draining very quickly please help me sir and fix it very soon sir please sir fix it as soon as possible thank you.
  16. Kvsm123
    Cupcake Sep 28, 2019
    Kvsm123 , Sep 28, 2019 :
    Take a look at my Battery stats. I flashed xXx No limit over OOS after rooting phone.
