8
One Plus 6 call connectivity issues on Vodafone network
  1. sdesai264 Eclair May 26, 2018
    sdesai264, May 26, 2018 :
    hello,
    Facing issues with reference to call connectivity - incoming on Vodafone India network on One Plus 6 device.
    inspite of full network , it's says not reachable
    the sim card has been changed. the sim card when inserted to other device does not face any issues.
    Even it works fine on One Plus 5 device.
    any solution to get rid of this issue on one plus 6 ?
  2. Lapik Cupcake May 26, 2018
    Lapik, May 26, 2018 :
    Facing the same issue on VidaVoda Czech Republic. I have to restart my OP6 to get mobile network back...
  3. bhartisooraj Cupcake May 27, 2018
    bhartisooraj, May 27, 2018 :
    Facing the same issue with Airtel, i have Airtel in my Sim Slot 2, and dont recieve any incoming calls inspite of showing full network, the only eay to get bavk is to give a call to any number.
    It brings me online for sometime but again it later starts showing me as switchedoff.
    Im loosing business...please help.
  4. X1527437856055 Cupcake May 27, 2018
  5. Prateek.Bindal Cupcake May 28, 2018
    Prateek.Bindal, May 28, 2018 :
    Agree with it.. one pluse 6 is giving network issues in Vodafone and Jio both while it shows full signal...
    Not able to make or receive calls at times even when network is full
    sarus_b likes this.
  6. bunny@1 Gingerbread May 28, 2018
    bunny@1, May 28, 2018 :
    Try to reset the Network settings and check if that helps!!
    Go to settings>>Back up and reset>>Reset network settings.
    Hope this helps!! :)
  7. srirammohancg Eclair May 28, 2018
    srirammohancg, May 28, 2018 :
    I'm using a Vodafone sim in slot 2 and facing network issues from day 1. I assumed my sim was corrupted and also changed the sim as well. But to my dismay the issue still persists. Oneplus can you please fix this immediately. There's zero network most of the times... Serious issue.
  8. srirammohancg Eclair May 28, 2018
    Issue still persists post reset as well
  9. prajnay0 Ice Cream Sandwich May 28, 2018
  10. saahill Gingerbread May 28, 2018
    sarus_b, Zayaan and chaitanyakhaitan like this.
  11. Anuraj26 Gingerbread May 28, 2018
    Anuraj26, May 28, 2018 :
    finally got a thread regarding this issue..I have been facing this issue since day 1 of my pu chase of one plus 6..HV been facing voice quality issue as well where other party complains of voice break and all..though my one plus 3 works absolutely fine with the same network..every now and then I see signal going off and have to restart the phone to get it back..even with full signal my number is out of reach or switched off..have already applied for the replacement..but I believe this issue will require a permanent fix from the One plus itself.
  12. Lapik Cupcake May 28, 2018
    Lapik, May 28, 2018 :
    I hope this is only a software issue which can be easily fixed with a next update... otherwise I'll have to apply for a replacement too.
  13. srirammohancg Eclair May 29, 2018
    srirammohancg, May 29, 2018 :
    I have already requested for a replacement. I am not able to receive any messages too. Too difficult to retrieve OTP messages as well. Seriously not expected this kind of flaw on a OnePlus.
    iPhone 6 was plagued with serious issues which we all know, hope OnePlus 6 doesn't turn out to be the same.
    chaitanyakhaitan likes this.
  14. piyush24 Gingerbread May 29, 2018
    piyush24, May 29, 2018 :
    Also, this is a Vodafone Network issue since not only OP6, but other phones too facing same issue.
    I am getting VoLTE on AirTel 4G and its fine.
  15. srirammohancg Eclair May 29, 2018
    This is not Vodafone issue as the same sim works perfectly fine on OP5T and OP3T. If it is Vodafone issue, it should not work on any phone.
  16. piyush24 Gingerbread May 29, 2018
    in my area - Vodafone network sucks.. else.. it works fine...
    and yes.. fhe sim tested by me is not working well on other phones - tested on Honor 8, Oneplus 3T
  17. Vatsal_Borda Cupcake May 29, 2018
  18. izzykasha KitKat May 29, 2018
  19. F_Siddharth_Jain_MiFI Cupcake Jun 1, 2018
    F_Siddharth_Jain_MiFI, Jun 1, 2018 :
    I have been facing the same issue on Airtel Postpaid India, have to restart my phone every half hour its seriously irritating ‍♂️
  20. P1527873803824 Cupcake Jun 1, 2018
    P1527873803824, Jun 1, 2018 :
    I agree with this ,, I am also a Vodafone user and often face call drop issue .. How to get it rectified or company is going to do something ???
    Have we been fooled by the company !!!
