one plus 6 charging issue
  1. Pranay Wadkar
    Cupcake Jan 20, 2020
    Pranay Wadkar , Jan 20, 2020 :
    Facing charging issues with one plus 6. when charger is plugged in ,it shows red light and no charging symbol appears. dash charging is not supporting. after plugging in and out multiple times , it shows phone is charging. it had been a month and this issue is not addressed. please look into it ASAP.
  2. The1Lion
    Marshmallow Jan 20, 2020
    The1Lion , Jan 20, 2020 :
    Are you using the provided dash charger and cable? Do you know anyone who also has a dash charger you can try to see if it's the charger or your phone?
    Caomhin likes this.
  3. tide1109
    Ice Cream Sandwich Jan 20, 2020
    tide1109 , Jan 20, 2020 :
    Try to clean your USB port and the connector of the cable. I could be, that one necessary pin is not connected. Because the charger can't identify a compatible device, it charges only at normal speed.
    Does standard charging and data transfer work fine?
    Kytharsis likes this.
