One plus 6 freezes and restarts while charging via OnePlus 6
  1. P1531488072168
    Cupcake Oct 12, 2019
    P1531488072168 , via OnePlus 6 , Oct 12, 2019 :
    I am having a trouble with the phone while charging because it freezes and restarts automatically after the latest update..
    Op6_O2_beta 25
    Is this a common problem or it would be preferable to opt out of the beta program.??
    Someone give me a solution on this problem.
  2. Raresch
    Ice Cream Sandwich Oct 13, 2019
  3. youngzy
    Cupcake Oct 13, 2019
    youngzy , Oct 13, 2019 :
    I had the same issue
    I found out once I plug in the charger, the system process takes 100% of CPU,which is the reason why the phone freezes and reboots.
    I've tried multiple ways, and it stopped acting like this.
    1. I uninstalled Android Auto
    2. I cleared all the data and cache for Google service(don't know if this helps,most likely not)
    Since it's an issue on charging, so I guess most likely the first one is the real solution.
    Let me know if your problem solved or not so that I can guess the real reason.
    P1531488072168 likes this.
  4. P1531488072168
    Cupcake Oct 16, 2019 at 9:06 AM
    P1531488072168 , via OnePlus 6 , Oct 16, 2019 at 9:06 AM :
    This was a issue due to unstable beta version... So I reverted bacl to the official stable version.
    Anyway thanks for the help
