one plus 6 problem
  1. E1538452776333 Cupcake Apr 18, 2019
  2. Nichrome Honeycomb Apr 18, 2019
  3. SeeBeeEss Ice Cream Sandwich Apr 18, 2019
    SeeBeeEss, Apr 18, 2019 :
    Posting problem
    You haven't given enough information.what should we do? ;)
    Kytharsis and Maverick2.0 like this.
  4. Aaron Hughey Donut Apr 18, 2019
  5. W1547046300268 Cupcake May 17, 2019 at 4:43 PM
  6. Angryaries77 Cupcake May 17, 2019 at 6:33 PM
    Angryaries77, May 17, 2019 at 6:33 PM :
    it has just started recently it is always loading connection despite having 100% data or wifi I have reset multiple times as well as factory reset Annis still losing connection or just hangs an doesn't do anything it shouldn't be doing this I got McLaren Ed just make sure wouldn't have issue anyone have answers
  7. Kytharsis Lollipop May 17, 2019 at 8:06 PM
    Kytharsis, May 17, 2019 at 8:06 PM :
    You haven't told us what apps you're using.
  8. W1547046300268 Cupcake May 17, 2019 at 8:08 PM
    W1547046300268, May 17, 2019 at 8:08 PM :
    it is not about using a particular app. it shows the UI stopped working.
    tThe data commection problem is also there and battery backup is a bis issue. suggest me what to do in this aituation
  9. Kytharsis Lollipop May 17, 2019 at 8:09 PM
    Kytharsis, May 17, 2019 at 8:09 PM :
    If the UI is stopping, that means something is wrong. When you reset the phone, did you repopulate your data from a backup?
  10. W1547046300268 Cupcake May 17, 2019 at 8:10 PM
  11. W1547046300268 Cupcake May 17, 2019 at 8:11 PM
  12. Kytharsis Lollipop May 17, 2019 at 8:11 PM
    Kytharsis, May 17, 2019 at 8:11 PM :
    Try formatting again but this time doing it from scratch. Something might've crept through the restoration process causing this problem.
  13. W1547046300268 Cupcake May 17, 2019 at 8:13 PM
  14. Kytharsis Lollipop May 17, 2019 at 8:13 PM
    Kytharsis, May 17, 2019 at 8:13 PM :
    Can't help ya there without screenshots. Also, for the record, there's no such thing as "battery backup" as there's nothing backing it up.
  15. W1547046300268 Cupcake May 17, 2019 at 8:13 PM
    W1547046300268, May 17, 2019 at 8:13 PM :
    I had already done it twice but the problem remain same as earlier.
  16. Kytharsis Lollipop May 17, 2019 at 8:17 PM
    Kytharsis, May 17, 2019 at 8:17 PM :
    Did you do what I suggested?
