One Plus 6 rear glass panel crack near volume keys
  1. L1540492539927
    Cupcake May 30, 2019
    L1540492539927 , May 30, 2019 :
    My one plus 6 gets cracked near the volume keys and i didn't dropped my phone from the date of purchase, used with the silicon case came with the phone and it's been only 7 months.
    I don't know how the back panel cracked and i also noticed some people faced the same problem like mine with the same pattern of cracking near the volume key. The picture below is mine
    and this one has same problem for another one plus 6 user
    Does any one face the same problem and will it be covered in the warranty for back panel replacement?? @David Y.
    SapSet likes this.
  2. Maverick2.0
    KitKat May 30, 2019
    Deactivated User, Xnatty and Artemus. like this.
  3. L1540492539927
    no i didn't banged it on any objects !!
  4. Artemus.
    Nougat May 30, 2019
    Artemus. , May 30, 2019 :
    Do you keep the phone in a compact area like a tight pocket or back pocket and sit on it?
    Nick 59, Xnatty and drl431 like this.
  5. L1540492539927
    Kytharsis
    Do you keep the phone in a compact area like a tight pocket or back pocket and sit on it?​
    I always carry the phone in front denim pocket and I'll take the phone from my pocket while sitting in the chair and i don't wear tight jean
  6. Artemus.
    Nougat May 30, 2019
    It's very possible the stress between your pocket and leg could've cracked it without you knowing.
    Maverick2.0 likes this.
  7. Deactivated User
    May 31, 2019
  8. SapSet
    Froyo Jun 1, 2019
    SapSet , Jun 1, 2019 :
    You never help !!! Write to people of nonsense. You do not understand the situation, you are incompetent !!! Stop writing your useless tips to people!
    L1540492539927 likes this.
  9. SapSet
    Froyo Jun 1, 2019
  10. SapSet
    Froyo Jun 1, 2019
    This is a well-known structural problem of OnePlus 6! Only you, as always, do not know, only useless advice and accusations give.
  11. L1540492539927
    Cupcake Jun 1, 2019
    L1540492539927 , Jun 1, 2019 :
    how come flagship phone can not handle day to day activities and
    which means there is no use in investing amount for flagship phone
    SapSet likes this.
  12. SapSet
    Froyo Jun 1, 2019
    Fully agree with you.
  13. W1559404636812
    Cupcake Jun 1, 2019
  14. SapSet
    Froyo Jun 1, 2019
    What kind of cheating? This problem has affected many owners of OnePlus 6. It's just that the company is silent about it!
  15. L1540492539927
    Cupcake Jun 1, 2019
    SapSet
    yeah how come it breaks in same pattern in same side and the difference is mine is smaller compared to others
    SapSet likes this.
  16. SapSet
    Froyo Jun 1, 2019
    You're right! This is no coincidence!
  17. Artemus.
    Nougat Jun 1, 2019
    Artemus. , Jun 1, 2019 :
    Curved class = brittle.
  18. SapSet
    Froyo Jun 1, 2019
    Is it true? Wow!?! Can not be?!?! Glass is fragile, how is that?!? (irony) Of course the glass is fragile, any normal person understands this. The thing is that OnePlus 6 has a construction problem!
  19. L1540492539927
    Cupcake Jun 1, 2019
