Working one plus 6t battery issue
  1. harshraj00
    Cupcake Feb 17, 2020
  2. R1581931411829
  3. Gav_W86
    Starting Point Expert Feb 17, 2020
    Gav_W86 , Feb 17, 2020 :
    battery use depends mostly on your use, what apps you have installed, and what settings/services are running.
    what do the battery use screens in settings say is using your battery?
    best to look after a full (100% to <10%) single charge use for best info.
    you can post screenshots (both the 1st screen that says screen on time and the app use screen) here if you need assistance interpreting.
  4. harshraj00
  5. R1581931411829
  6. harshraj00
  7. R1581931411829
  8. harshraj00
  9. R1581931411829
  10. harshraj00
    harshraj00 , Feb 17, 2020 :
    omni rom,paranoid,google pixel 4 and aosip rom.
  11. R1581931411829
    R1581931411829 , Feb 17, 2020 :
    really after trying all these roms still the issue continues ??
    unbelievable !! although i am not seeing many FIXED battery drain posts
  12. harshraj00
    I am very disappointed with this.
  13. Gav_W86
    people don't often come back and say things are now working better, just the initial complaint. That is why you need to look at what the stats say.
    If the other user has used lots of other ROMs and still has an issue, then either there is a physical issue with the battery, or its the way it is being used. Given one of his other posts complains about battery being used when gaming and not understanding that is normal, I would think the latter.
  14. R1581931411829
    are you using a oneplus 6t and have faced the same issue ??
  15. Gav_W86
    I have 3 OnePlus devices on the go, my battery use is related to the use I make of the phone, that is why I say to look at the battery use stats in Settings.
  16. harshraj00
    when i use my device normally it consume 7-8% battery withing 5-6 minutes.
    R1581931411829 likes this.
  17. Sun90
    Sun90 , Feb 17, 2020 :
    Post the screen shot of your phone's battery stats.
  18. R1581931411829
    Cupcake Feb 18, 2020
    R1581931411829 , Feb 18, 2020 :
    you have not answered both my questions !!! they are simple questions ? yes/no
  19. Gav_W86
    Starting Point Expert Feb 18, 2020
    Gav_W86 , Feb 18, 2020 :
    yes and no.
  20. R1581931411829
